Question about Dell Dimension 3000 PC Desktop
I have no sound on my pc--->dell dimension 3000 please help me... :D
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reginout to scan for errors.
Posted on Oct 22, 2010
Hello Mr. Expert I have a Dell Dimension 3000 desktop. I upgraded to bios to A03. Is it possible to upgrade to a higher version. Thanks,
Hi!
The A03 is for now the latest version for the BIOS of Dell Dimension 3000
And a tip for you: upgrading bios is only necessary when real issues occure and the computer doesn't work properly.
Please let me know if it helped
Best regards!
Aug 09, 2011 | Dell Dimension 3000 PC Desktop
I put a new harddrive in my dell dimension 3000. and once the OS was done and windows started up i could not adjust the resolution or go on the enternet. also no sound? what is am doing wrong
You need to get ethernet,graphics and audio drivers
to get internet , screen ,sound to work!
Get the right drivers and it will work!
Please vote!
May 13, 2010 | Dell Dimension 3000 PC Desktop
I'm trying to reformat the hard drive on my dell dimension 3000 desktop after a virus. I don't seem to have the system restore function anymore. I do have the original cd with windows.
The restore function is available in the system properties... Also if it is not available then
Go to Control Panel -> Add Remove Programs -> Windows Components -> Accessories
Click Details and click System restore option
Apr 25, 2010 | Dell Dimension 3000 PC Desktop
No sound on my Dell Dimension 3000
i would try checking the plug for your speakers to see if it is loose.
If you move the plug is there any static that comes from the speakers?
If you have headphones maybe try plugging them in to see if you have sound through them.
If you do have sound then i would say it is your speakers that are bad.
If you get no sound or scratchy sound through the headphones, then i would suspect either a loose jack connection for your audio or a dying audio chip.
Feb 14, 2010 | Dell Dimension 3000 PC Desktop
I am looking for a way to take off the side panel, as I am assuming this is where the new memory has to go on the dell dimension 3000 desktop
Unscrew 1-2 screws from the side panel.
If your computer cover has a cover latch, slide and hold the cover latch.
Grip the indents on the computer cover, and slide the computer cover toward the back of the computer.
Jul 09, 2009 | Dell Computers & Internet
MY SOUND WILL NOT WORK DIMENTION 3000
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&cs=19&l=en&s=dhs&~mode=popup&file=122481
Click on the above Link, This is the exact drivers for your computer.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 17, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
41 people viewed this question
Alun Cox
