Question about Garmin GPS
How do I find out if my alternator is chargng my battery on my CubCrafters sport cub with my 469
  • rudy_zubille Oct 04, 2010
    The Garmin has its own Battery backup,and seems to be ok , doesn't the 496 have a page that shows if the Aircraft battery is being charged or how the alternator is working ?
    President:
  • 1,139 Answers
Literally the way to find out if any charging system is charging properly whether it be car, bike, plane, anything, measure the battery voltage with a voltmeter before the engine is started. Keeping the voltmeter attached start the engine and see how much the voltage rises to. It should be roughly 2 volts more than the battery voltage was at before it was started.
Hope this helps
Posted on Oct 04, 2010
    Genius:
  • 1,478 Answers
If you are able to put on your device without any stress after the device as been put off for few hours, it means the alternator is charging your device,, also, if your device did not indicate any sign of battery low while the device is on, it shows the alternator is charging it.
Take care.
Show me how to wire farmall cub tractor when converting from 6 volt to 12 volt. It's a 1951 farmall cub
Replace the coil with a 12volt coil. Replace the generator with an alternator. Replace any light bulbs with 12volt. Fit the new 12volt battery in with the negative terminal to chassis! and there you have it.
Feb 02, 2017 | Farmall Garden
Cub cadet mower turns off when I slow down
one more possible check. Make sure the battery is fully charged. Then try it. You might put jumpers from the car on to do a check without doing the battery check. If it runs with the car battery, most likely in battery, or alternator.
Jun 20, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Alternator not chargng
Hi Luis,your alternator has a fusible link,yours may be blown, follow positive battery cable to them and check.
Nov 11, 2013 | 1999 Nissan Frontier
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Battery drained after use
A lot of automotive parts stores will check a battery for free...
find your lowest amp rated (less than 10) and charge it over night.
Have battery load tested.
if good, place ammeter between battery and the rest of the tractor to check and see if load from running engine is draining or alternator isn't working.
or fast way to check an alternator on almost anything, start with battery, the pull off the negative (black) cable, if engine dies nothing is powering the engine but the battery (on an alternator driven electrical system, the battery is only used to start the engine)
May 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2002 mitsubushi montero sport. The brake/battery light won't go off. I replaced the battery yesterday and car starts and stays running but lights seem a little dim and the dang brake/battery...
CHECK ALTERNATOR DRIVE BELT COULD BE LOOSE NEED ADJUSTING OR GLAZED NEED REPLACING. IF ALL IS GOOD, CHECK ALTERNATOR VOLTAGE OUT PUT AT BATTERY SHOULD BE 13.5 - 14.5 VOLTS. IF NOT ALTERNATOR FAULTY BUT CHECK ALTERNATOR BATTERY FEED AND VOLTAGE REGULATOR WIRES FOR LOOSE CONNECTION OR DAMAGED FRAYED WIRES. CHECK ALTERNATOR FUSE.CHECK THOSE THINGS BEFORE BUYING NEW ALTERNATOR.FIRST TURN OFF RADIO BEFORE DISCONNECTING BATTERY CABLE TO KEEP FROM LOCKING OUT RADIO.
Aug 05, 2011 | 2002 Mitsubishi Montero Sport
GPS Logo
22 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
