Program Allegro MBC4025 for tv
How do I program my Allegro MBC4025 for TV?
  • Anonymous Aug 27, 2008
    how to program to tv
5 Suggested Answers
baghdad_love
  • 56 Answers
SOURCE: locateowners manual/program codes for tv remote
all you need is there ... the codes: http://www.jensen.com/home_electronics
Posted on Jul 31, 2007
SOURCE: program for my tv
Push the t.v. button on the remote then push and hold the on/off button and the t.v. button down at the same time until the on/off button comes back on and stays on, then you release them both. Then push the CH+ or channel up button on the remote and the on/off button alternatively until the t.v. goes off or comes on, each time you hit the CH+ button on the remote you are advancing the code for you t.v. forward in your remote, after your t.v. comes on or off then hit the stop button on the bottom of the remote and you have stored the code for your t.v. Hope this helps.
Posted on Oct 21, 2007
wyoed1
  • 211 Answers
SOURCE: cant program directtv remote to sony tv
See if this web sight helps in your problem
Good Luck and have a great day.
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 26, 2008
  • 3 Answers
SOURCE: how can i program my rc16 direc tv remote control to my philips tv
I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
Posted on Dec 17, 2008
Allegro MBC4025 universal remote codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Nov 21, 2016 | Sanyo Televison & Video
I want to change the dialing number on my allegro GE security system, part no. 60-874-95R. Can you help with this without the vendor's help? Thanks
Follow the instruction on the install manual, page 7. you should start by cleaning the memory of all the previous data - as explained in page 6.
If you don't have the manual get it from here
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ALLEGRO_Install.pdf
Sep 07, 2011 | Allegro Ge Iti Allegro 80-795 / 60-879-95r...
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
Can't record tv programs onto VHS tape....
you need to connect the cable source directly to the vcr and then from the vcr to the tv,and put the channel you want to record on the vcr,good luck
Feb 02, 2010 | Allegro DVD/VCR ABV511
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
I need program for remote control-AT&T 200b
Sharp 026 • 091 • 129 • 141
the guide can be retrieved from
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/us_electronics_uf4200c_manual.pdf
On the remote control, press and hold the appropriate mode key (TV button) until the four mode
keys flash twice. The mode key will continue to flash.
Enter the three-digit code. See above I gave all the Sharp codes.
After you press the first digit, the mode key should light and stay on. After you press
the last digit, the mode key should flash three times and turn off.
If the mode key does not flash three times before turning off, the code is invalid for
this device type. Repeat the procedure with another device code.
Point the remote at the device and press POWER. If the device turns on or off, you
have finished programming.
If you have tried all the codes listed for the manufacturer and the device does not
respond, refer to the CodeScan™ section later in this manual.
Jan 07, 2009 | Allegro DVD Recorder VCR Combo ABR521
Programming remote
Code Numbers for TV
Lg/golstar..................1 or 2
Zenith.........................1 or 2 or 3
Samsung..................6 or 7
Sony...........................8 or 9
Hitachi........................4
Hold down "TV POWER BUTTON"....while holding hold button press above number for your TV.
Aug 11, 2008 | Allegro DVD/VCR ABV511
How to turn off progressive scan on Allegro Dvd Player
yeah.same here.=[
but it only says that for the dvd mode.
Oct 24, 2007 | Allegro DVD/VCR ABV511
Programming remote for Zenith DVB412 DVD Player
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
  1. While holding down TV POWER button, press the number buttons to select the manufacturer code for your TV (see the table).
  2. Release TV POWER button. Code numbers of controllable TVs If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
Jun 30, 2006 | Zenith DVB412 DVD Player
Televison & Video Logo
489 people viewed this question
Top Televison & Video Experts
Electro Med Services...
