Question about Roper RGX4634KQ Gas Dryer
Location of belt - Roper RGX4634KQ Gas Dryer
It's around the outside of the tub. To access, you have to remove the top. To do this, remove the two phillips screws under the filter door. Remove the filter. The top is spring loaded to the rear. Pull one side at a time to the front and lift up. When both sides are free, lift up like a car hood.
Posted on Oct 06, 2010
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
1996 Ford contour automatic 2.0 L with air-conditioning and no turbo. How do I change the serpentine belt
Either locate the belt routing diagram that is usually located under the hood somewhere, or take a photo of the path of the current belt. Locate the belt tensioner pulley. Using an appropriate ratchet or belt removal tool, release tension on the old belt and slide the old belt off the pulleys. Thread the new belt over the pulleys in the same configuration as the diagram (or photo), release tension of the tensioner and slide the belt on it. Allow the tensioner to take up the belt slack. Inspect the belt for proper routing and to ensure that it is on all pulleys correctly.
Dec 10, 2015 | Ford Cars & Trucks
Squealing noise in park
If youre just idiling, then it may just be the serpentine belt that needs to be replaced.
Mar 05, 2015 | 2004 Jeep Grand Cherokee
I dont know how to releave the tension to remove the belt
If you are talking about a serpentine belt on a car; you need to locate the tensioner pulley. A tensioner pulley is spring loaded to press on the belt to ensure the the belt stays on "track". It is usually located towards the top of your belt pulley system. Turn the nut located in the center of the tensioner pulley. That will relieve the tension and allow you to replace your serpentine belt.7fabd47.png
Oct 21, 2010 | Computers & Internet
Where is the fan belt located on a suzuki swift?
It dosent have a fan belt it should be an electric fan mounted on your radiator if its making a squeeling belt noise its probly the altinator belt located on the righthand side of the engine bay.
Jul 10, 2010 | 1990 Suzuki Swift
Cable to engage the self propelled pully came loose. How do i reattach it?
Instructions
Step 1 Locate the spark plug wire, and disconnect it from the spark plug.
Step 2 Remove the screw that is used to secure the belt cover to the mower with a screwdriver. Take the belt cover off of the mower.
Step 3 Loosen the belt tension bolt with the socket wrench. The belt tension bolt is located next to the wheel adjustment lever on the left front of the mower.
Step 4 Pull the front part of the drive belt off of the transmission pulley that is located on top of the motor.
Step 5 Tilt the mower on its side, and pull the rear part of the drive belt over the mower blade.
Step 6 Insert the rear of the new drive belt over the mower blade, and place the front of the belt over the transmission pulley.
Step 7 Tighten the belt tension bolt with the socket wrench.
Step 8 Locate the adjuster nut located on the underside of the mower near the belt tension bolt.
Step 9 Tighten the nut with the wrench until it touches the spacer, and slightly loosen the nut so that the spacer can turn.
Step 10 Set the belt cover back onto the mower, and secure it with the screw.
Step 11 Re-connect the spark plug wire to the spark plug.
Good Luck!
Jun 19, 2010 | Garden
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Not working, theres power but nothings working? belt maybe, where is the belt located? If not what els could it be? and where would that be located?
There should be a trouble door in the back so you can see the belt. If the motor is not running, I would check the door switch first. The pcappliancerepair.com site has parts and help.
May 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do I locate tension wheel to replace serpntne belts 04 sentra
The serpentine belt runs everyting under the hood...easiest way to locate the tension wheel is to look at every other wheel that the belt runs to.
Your tension wheel will be where the belt runs without being in a V channel, the tension wheel will be flat..no grooves to accomodate the belt.
Hope this helps
Feb 01, 2009 | 2004 Nissan Sentra
Roper RGX4634KQ Gas Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
