Question about Electrolux Central Vacuum
I have a NUTONE central vac, when I turn on the power, It sounds like its grinding glass and doesnt suction. Could it be that broken glass got caught in the motor and all I need to do is clean it, or is this the sound of a failed motor?
  • 694 Answers
More likely it's something in the fan. However, I suggest taking it to a vacuum repair shop to make sure. Something could have got into the fan system and is making a racket, but the motor itself won't crunch up glass.
Posted on Oct 04, 2010
  • vitaeterna20 Nov 10, 2010
    Taking the fan apart will cost you over $100.00 from my experience. It is possible to do it yourself, but it is not easy. The fan assembly is friction fit together and you need to use a hammer and chisel to ease it apart on one side and then the other. Make sure you have something through the hole to keep all the pieces inside in the same order as when everything was together. If the bearings are shot, I managed to the the old race case out by using a pair of pliers against the edge for leverage.
I have a broan central vac 24 yrs old ,vac works if you turn sw on cannister,not by plugging hose att,is this a major problem,thanks
Broan 450 air-watt and 8.5 amp power unit. Covers 3,000 sq. one 30-ft. crush-proof hose with on/off switch, one 10-in. wide hard floor brush features swivel neck for easy maneuverability around furniture. My new home is just under 2000sf. Will this new unit have enough suction?? Just buy or don't??
Jan 22, 2013 | Broan-NuTone CV350 Central Vacuum
Poor suction in system - I have used shop vac to suction all three receptacles. Have checked bag and cleaned everything. Still poor suction. I have one receptacle in garage that works perfectly. Must...
Have you checked the hose for clogs or leaks. Clogged and leaky hoses are an area of concern with any central vac. Unless you hose has a hose sock, then wear and tear from constant rubbing on floors and other surfaces will result in holes and cracks. Pulling the hose can also result in leaks where the hose attaches to the handle and intake connector.
Mix some dish soap with water.
Use shop vac to blow air through hose, with other end capped or "clogged".
Apply soap solution to each end of hose.
If bubbles form, this indicates leakage. Hose will need to be replaced.
Oct 25, 2010 | Broan-NuTone CV450 Central Bagged Central...
No suction
Use the guide at builtinvacuum.com/flowchrt.html to find the issue and solution. Most likely you need to test it without any filter and be sure the bottom of the unit is attached :) To get access to the motors you need to unbolt the very top sides.
Jul 28, 2010 | Broan-NuTone CV350 Performance Bagged...
Have a nutone CV-450. Suction is gone at the
The first thing to do is to disconnect the pipe coming into the unit. If there is suction there than you probably have a break in the line. If there is no suction when you disconnect the pipe coming into the unit than it is most likely the motor gasket. This gasket can sometimes get sucked into the motor causing problems. Remove the lid to the central vacuum, than disconnect the motor, you should be able to tell if maybe the gasket has been off center or if it has been sucked up in the motor.
Dec 13, 2009 | Broan-NuTone CV450 Central Bagged Central...
NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Mar 11, 2009 | Broan-NuTone VX475 Bagged Central System...
NuTone CV353 Central Vac does not start when hose is plugged into
Try to plug the hose in sideways. So the top of the hose is rotated 90 degrees. If the unit turns on then there is something wrong with the hose. It might be a short or it could be a bad switch on the handle. If the unit still wont turn on I would think that maybe the low voltage wire got disconnected from the unit or there is a break in the low voltage wire somewhere along the way. Let me know if you plugging the hose in sideways works.
Feb 22, 2009 | Broan-NuTone CV353 Central Vacuum
CENTRAL VACUUM SYSTEM
Disconnect the inlet piping from the unit and check the suction there. Be sure that the utility inlet on the unit is closed. If you have good suction, you have an open/broken pipe somewhere, or possible an inlet valve or vacpan that is not sealing when closed. The easiest way to find it would be to install your tubing back into the inlet of the unit, turn the unit on, and walk around the house listening for air leaks. Good Luck!!
Jun 29, 2008 | Broan-NuTone CV353 Central Vacuum
No suction on lower level
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=539794
Generic problem for all Vacuums
Posted by phil55555 on Apr 23, 2008
Nutone central vac
no suction on lower level second floor fine
ran fish tape but it does not go all the way through,
do i need to take pipe out.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not @ first, try to get a central vacuum cuff and go to each and every inlet / outlet down the basement and put the cuff in the inlet – the central vac should come on and possibly might unclog the pipe, 2nd, try taking another canister type vacuum while the central vac is running and open the inlet door and try to “pull apart the clog in the pipe” – this does work upon occasion if not you can try a plumbers snake – but be careful because the walls of the pvc pipe are thin wall and you don’t want to poke a hole in the pipe or other wise you will have to replace the pipe. The absolute last resort should be to replace the pipe if all other do not work. Feel free to contact your local vacuum dealer in your area or in the yellow pages , or contact the factory @ the phone #’s listed below:
http://nutone.com --- Customer Service
NuTone Inc.
9825 Kenwood Road Suite 301
Cincinnati, OH 45242
In U.S.A. call:
1-888-336-3948 for Customer Service
1-888-336-6151 for Technical Support
In Canada call: 1-888-882-7626
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Vacuums Logo
53 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
