Question about Kenmore 24 in. 17032 Built-in Dishwasher
Noise, Noise, NOISE
My Kenmore 665.17532 sounds like a cat being tortured! A very loud cat at that. I can barely hear the TV in an adjacent room with the door closed.This noise has been going on for months; washing is ok tho.
Nothing found in the chopper or accumulator.
Help...
John Swapceinski
  • jpswap May 28, 2008
    Howdy Illeagle:
    You may be right about the bearings but, the rotor turns freely without any apparent roughness. Will let you know outcome if I can id the problem with any certainty. Thanks for your time.
    John
  • 525 Answers
Barring an actual cat being inside the dishwasher, I would surmise that the motor bearings are starved for lubricant, which is something that is not normally done. Sounds like its time for a new dishwasher
Posted on May 27, 2008
  • David Emmel
    David Emmel May 29, 2008
    You are very welcome, and thank you for the generous rating!
    Another thought came to mind. I have heard some dishwashers give off a high pitched squealing sound. This was found to be caused by the main water seal and drain impeller, located just above the motor. Replacing this may resolve your kitty cat issue.
    Keep me posted, and thanks again.
    Dave,(Illeagle)
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Lcd tv music is too loud to hear voices
hi i don't know if this will work go into the menu on the tv look for noise reduction turn it off or check your sound settings hope it helps
regards
shaun
Apr 02, 2014 | JVC LT-40X776 40 in. LCD HDTV
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Emerson EWC20D3 20 in. TV/DVD Combo what is that loud whining noise from the back
What happens in this case is a small transformer or the high voltage transformer vibrate hard enough to make that sound--not loose or bad but can cause the vibration.
I have seen in customer's homes where it was loud enough to chase cats right out of the room even in a large room.
Two ways to deal with this----with the set apart locate the part by ear or even probing with a plastic tool---when you press close to it, the sound will diminish or go away.
Believe it or not (in our shop) once located we use a hot glue gun to take the sound away---
usually if very loud it is the high voltage transformer on the main TV board (see photo of a typical one) not on the black part but on the iron like (it is a different material) core that looks like a U bolt.
it can irritate but poses no danger.
Mar 28, 2012 | Emerson EWC20D3 20 in. TV/DVD Combo
Intermittent loud noise
more than likely is the pump the noise your hearing is most likely the bearings or the coling bladed on the motor
Jul 26, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Ambient sound is louder than the music
I have a Mac (OS X 10.5.7) and had the same problem with the Ion TTUSB system picking up room noise. This seemed to fix it:
In System Preference, under Hardware, choose "Sound".
Choose "Input".
Under "Choose a device for sound input" choose USB Audio CODEC  type: USB
I hope this helps,
Cheers!
Jul 05, 2009 | ION Audio TTUSB10 Turntable
Vacuum making loud noise (like hole in tube)
I have the same vacuum - it's a clog in the brush area, or where the hose connects to the base. Unhook the hose, like you're going to use a tool. Lay the vacuum flat, so you can stick something in the plastic tube (at the base where you disconnected the hose) without the awkward angle. I use a dryer vent cleaner, but you could probably use a wire hanger. Push through until it comes out through the brush area...should fix your problem.
Nov 13, 2008 | Kenmore Progressive Bagless Upright with...
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 24 in. 17032 Built-in Dishwasher Logo
255 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
