Question about HP Laserjet M2727nf Multifunction Printer
Message on screen reads: "scanner error 5 turn off and on" turned copier off and on, also unplugged it. No success... WE do not scanner on this machine - only make copies. Please aadvise... Thank You
  • 152 Answers
This sounds like a Scanner/Flatbed Problem. This series of printers have a known problem with this component. The scanner is failing to initialize itself. The scanner does need to be changed by an Authorized HP Warranty Repair Facility. It is possible that it may be covered under an HP Extended Warranty program. See repair information VIA posted Link.
M2727INFORMATION
Cheers!!
Posted on Feb 04, 2011
Setup/configuration issue, error message, scanner error 0x10. How do I fix this?
unplug power at the wall outlet
wait 5 minutes
press and hold the power/on button for 60+ seconds
keep holding while plugging back in, and for another 60 seconds after, then release if that doesnt work it is an internal fault which would require repairs or exchange in your case
Jul 19, 2015 | Epson Expression Home XP-420 Wireless...
Scanner error message
is your printer is detected in the device manager settings??
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Lanier 5227 scanner error
Eenter in the service mode press yellow key - 107 - red key(stop) keep press for 5 seconds,enter in the SP mode open the front door,turn OFF the main switch,wait 15 seconds close the front door,turn ON the power switch.
Jan 22, 2012 | Lanier Office Equipment & Supplies
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
Everytime I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your...
when I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your documentation". Then all the lights start flashing, And then I cant do anything, but turn the printer off.
I have turned it off and unplugged it and tryed again always same result.
bdl12920@aol.com
May 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Fax problem
first try to make a copy and check if you get the same error message..
if you get the same error message..try these steps..
1)connect the printer directly to the wall outlet..and try to make a copy..if you get the same error message..then go the next step
2)unplug the power chord from the back of the printer..press and hold OK and CANCEL buttons together..
3)while pressing these two buttons plug in the power chord to the back of the printer..after you plug in the power chord do not release the buttons untill the screen goes blank..
4)once the screen is blank release the buttons and turn ON the printer..
5)wait for the printer to complete the initialization..
6)then try to make a copy and check if it is copying successfully..
if not machine should be replaced because scanner bulb is not getting enough power or scanner bulb is gone bad..
please try these steps and let me if the solution has worked
Mar 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanner Error Power Turn off than on
If you are get that error message than unplug the power cord, and than press Poun and Number 6 Keys together on the keypab of the printer. While these keys are pressed and hold, than at the same time plugged in the power cord and dont release the two buttons.
After say 30 second you will get a new message on the screen of the printer.
All of the above steps actually reset the printer. I hope this will work.
Regards,
Lalit
Aug 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Error message
Unfortunately, if an HP scanner quits functioning, the whole unit is dead. You may want to unplug the printer from its power source and USB cable for about 5 minutes, plug them all back in and then retry. Sometimes, a scanner job can get stuck in the spooler and cause the whole thing to stop working until the job is done (even though there isn't a job to do). I had this issue once and this worked.
Jan 20, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Scanner Failure Message keeps popping up
Here it is all over, with all the steps.
1.Unplug power cable from printer.
2.Hold Cancel and Enter. OR you could Hold Cancel and Black Copy Button. Whichever is easier
3.Then plug back in the power cable, while still holding those 2 buttons.
4.It should turn on, lights blink, then it should say FULL RESET on the little screen thingy .
5.Let go of the buttons, and hopefully, it fixed your problem.
Nov 29, 2007 | HP PSC 750 All-In-One InkJet Printer
HP Laserjet M2727nf Multifunction Printer Logo
138 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
