Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Oshiba 42H81 42
va123 on May 27, 2008
I did all the things you said and replaced 110 with 150. Once i kept every thing back and turned on the tv I get nothing I see some green light very little but i get no picture or sound.
Comments:
May 28, 2008
- Thank you so much for replying I will check . I replaced 2 of STK392-110 with STK392-150 . I bought them on line at https://www.bluestar-online.com paid $16.00 for both.
I will check F850,F851 fuses = 5 amp micro and will let you know . thanks a lot I really want to fix my TV :( hope this will work.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Nov 03, 2008
-   replaced stk192-110's with stk192-150's. now all I get is colored screen and no menu. help please-   easy tony
Best Solution
posted on May 28, 2008
Helpful)
Terryfic
Rank: Guru  Toshiba ExpertToshiba Expert
Rating: 87%, 1634 votes
Check F850,F851 fuses = 5 amp micro ( black ) soldered in.
Did you use -150's from kit X480293 or ? What price did you pay?...............................T.
Comments:
May 28, 2008
- Best choice for IC replacement is X480293 Kit with two IC's
$32.00 wholesale ( they won't blow fuses ). ...T.
Was this helpful?
Yes
No
Related Problems
My Toshiba 42H81 has no picture and has a red blinking light...
Toshiba HMX94 DLP I replaced the bulb after it crashed and...
i gave my son my 42 inch rear projection last year,for the...
push power and sounds like it turns on but it doesnt
Can you Help with these Projection Television problems?
the screen is jumping and there is a...
Solve
the screen is jumping and there is a touch focus error how do I fix it?
depreciation
Solve
how to create a depreciation entries?
I can' rember how to do the...
Solve
I can' rember how to do the convergence on the tv,
Screen is all Yellow
Solve
Tv was working okay then all of a sudden the screen just went yellow have tried the other channels... (More)
Sponsored Links
Describe your TV & Video problem:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
        JR  ELECTRONICS
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
