Question about Craftsman Nailer Kit, Palm Air Driver
Primegrip flooring nailer does not sink nail heads enough. No other noted problems though. Need to get new punch? Anyone have any ideas?
3 Suggested Answers
  • 256 Answers
SOURCE: nailer drives one nail but driver pin doesn,t
Remove the air hose and open the nailer head section. Look for a foreign object in this are that could be jamming the drive pin. Also, make sure you are using the right size nails.
Posted on Jul 11, 2009
SOURCE: The nails aren't going in far enough using a air cleat nailer
I just finished 800 square feet of oak flooring with this nailer. You might have to increase the psi at the gun and make sure it gets a good square firm hit to set the nail. You can swing and hit the thing pretty hard, I hit it hard to set warped boards in place. I used 120 psi for best results, I tried 90 psi but had more misfires. The nail head only needs to set in far enough so the head is touching the tongue and so the next board will fit. The nail won't be buried into the tongue like you might think. If the occasional nail protrudes from the board you can use a nail set to drive the nail the rest of the way in, but I found that most of the nails didn't want to set by hand. I either clipped off the head with side cutters and folded over the remaining tab or did my best to set the nail if it wasn't long enough to clip. If it bends over really ugly, just carve a little wood from the groove lands on the next board to clear the nail stub. Removing the nails is difficult, it's best to let them be rather than risk damaging the flooring. Also, don't let the gun get down to the last nail. Sometimes if you try to fire the last nail on a strip it will twist and damage the flooring. Always keep a few nails in the gun just to be safe. Hope this helps.
Posted on Nov 25, 2008
My gr200lcn floor nailer keeps getting nail stuck in it on the first nail filred
Depending on amout of use, driver blades do need to be ground square or replaced to make full contact with the nail head . There could be other factors causing problem however. The nails do need to align with the path of the driver. Make sure that the first nail is directly under the path of the driver. If the nails are not made correctly or the wrong nails are in the gun, the angle of the nails may be preventing full contact of the driver to nail head. Good luck
Dec 24, 2012 | Grip Rite GripRite GR200LCN 2 Floor Cleat...
PORTOMATIC NAILER . WILL NOT COUNTERSINK NAILS PSI 100
On many floor nailers, counter sink is controlled by the thickness of lower pad. Your nailer most likely uses several different thickness of pads bolted to the bottom surface of the gun (usually white vinyl /plastic). The thinner the pad, the deeper the nail will set. Good luck.
Oct 31, 2012 | Air Tools & Compressors
Common problems dewalt clipped head framing nailer
there is NO easy solution for this, but unplug air and get a pair of safety glasses and a punch and try and knock the driver up into the tool away from the nail or if it is just jammed try and pull the nail out. You didn't really specify where the problem is. Let me know if you need more assistance.
Jan 05, 2012 | Dewalt D51822 Clipped Head 2Inch to...
Bostitch MIII Nailer Nail Jam Problem .... the end of what appears to be the last 2 inch nail is protruding out the bottom & is stuck. I can't get it out / remove it. The protruding part looks...
You may try to see if the plunger is in a down position, if so you may be able to take a screw dirver or punch of some sort and drive the plunger back into the head and free up the nail that is wedged in the feed chamber. Hope this helps. Good Luck.
Sep 15, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
I rented a Bostitch Floor Nailer from Home Depot, and the nails wont set into the maple flooring. Iv used three different compressors(all set to 90psi) and 4 different Bostitch Nail Guns. Im going out of...
Ive had the same problem where it was putting divits you could see from the staples, we ended up changing out the flooring completely. Only thing besides trying diff psi's to get it perfect and different length staples/different heads on staples(nails) , maybe try staple gun. Keep trying every woods different, odd that it started half way through job.. odd.
Jul 15, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
Using recommended 3 1/2" nails; cannot get the nailer to sink the nail all the way to the head. Depth is set to max and air pressure within recommended range of 70 to 120 p. s. i. g.
remove the nails and air hose. tap the gun lightly and does the driver fall down?? if so it needs new o rings and doesn't have enough seal to drive the nail. also look at the condition of the driver. FOLLOW CLOSELY, reconnect the gun and remove the nails pull back on the follower and using a piece of wood to activate the safety hold gun at an angle, weara safety glasses and depress and hold trigger to expose the driver, does it extend past the nose and LOOK DONT TOUCH to check the condition of the end. release the trigger. this should give you some ideas why. also recheck the nails for proper collation and head are they clipped or full round. Let me know and I will try and help further. READ closely before attempting the above ideas.
Aug 26, 2010 | Stanley Bostitch F21PL Nailer
My Primegrip nailer has broken; the piston part; I need it to be fixed
i have the parts for prime grip flooring nailer ...and we do fix them.
contact ; Dk 416 830 3046 Scarborough Toronto
May 02, 2010 | Craftsman Nailer Kit, Palm Air Driver
Using the BOstitch flooring nailer, good air pressure and using cleats. but when i tap with hammer noting happens. the nailer goes off as if it had gone off but no nail was driven.
1. check to make sure the magazine does not contain a jam.
2. check to make sure the driver retracts fully to allow the cleat to advance
3. Be sure to have at least 90psi and to hit the head hard enough to fully fire the nailer.
Sep 25, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Floor nailer, 2" nail not going into harwood
sounds like a bent shaft has the driver had any nail stuck or came out the side? whats the presser on?Are you nailing over exiting floor such as v.c.t or other hardwood floor try a couple drops oil in the nailer i' ve been doing floors for over 30 years these are some of the problems i came across hope its helps some what
Dec 23, 2008 | Farberware Manual Hardwood Flooring Nailer...
Nov 23, 2008 | Porter Cable 2" Flooring Cleat Nailer...
Craftsman Nailer Kit, Palm Air Driver Logo
266 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
