Question about Samsung Televison & Video
SAMSUNG DLP HL-T5087SA COLOR TINT VERY BLUE OR VERY GREEN?
SOURCE: How to change the color wheel of Samsung HL-P5063W
Look on Youtube for samsung color wheel. you should find your answers there...
Posted on Aug 02, 2008
  • 185 Answers
SOURCE: no blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Posted on Dec 26, 2008
romsky79
  • 822 Answers
SOURCE: green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
Posted on May 30, 2009
SD Tech
  • 14553 Answers
SOURCE: replaced color wheel on samsung dlp Color can't be adjusted
Some of these sets have a jumper plug that has to be removed when you install the newer type of color wheel.
The jumper if it has it usually causes the color to look funny blue instead of normal.
It is located on the DMD board--the metal box on the light engine where the two plugs from the color wheel are.
It will be in a small opening on the metal shield that covers it--small and rectangular in shape--it has a small metal tab across it--it jumps two pins--
if it is there with a hemostat or small needle nose pliers pull it carefully out and see what you have--The CCA adjustments are done in the TECH MENU--look to see first if the jumper is there and remove it.
A lot of places that sell the wheel do not tell people about this.
If this has helped you rate this solution, as I do this here for FREE.
sd tech
Posted on Nov 18, 2009
SOURCE: Samsung HLN617W DLP 61" TV only show green color
Check your color wheel.(These shatter) Can purchase these at Electrified Discounters
Posted on Jan 28, 2010
67" Samsung DLP. Last night it started flicker to a green tint. Back to normal then green tint. Now it's completely a green tint. Still has picture and voice but green tint and not bright like before.
In those sets there is what they call color wheel and it could be on its way out it sounds like its stuck.or not working prop in any case you need to bring it in for service place
Mar 26, 2013 | Televison & Video
Samsung dlp model HL-T5087SA has audio but no picture
Check the bulb. If bulb is OK, check the Ballast board.
Apr 15, 2012 | Samsung DLP HL-P5663W 56" TV
I have a SAMSUM HL-T6187SA DLP LED 1080P. The problems I see are a Green Tint and the RED(s) display as Blue(ish). John
It sound likes the problem of your unit is the light engine. This is very common problem on Samsung DLP TV's and tons of complaint regarding on the picture quality. If you search "Samsung DLP law suit" you will find various comment regarding on the issue.
This part is an expensive one and I would advice you to call Samsung service department (1-800-726-7864) to let it diagnose by their Technician and see if they would cover the parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 25, 2011 | Samsung HL-T6187S Television
50 inch samsung tv has red tint n dis colored
Hi
please try to reset the color settings then hit the tint color adjustment, if nothing change, you have a problem with the RGB Section that is need to replace some small parts!
Thanks!
Jan 14, 2009 | Samsung DLP HL-P5663W 56" TV
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Color problem
Samsung color wheel fix
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 13, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
166 people viewed this question
Jerry Greenberg
Jerry Greenberg
