Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
My HP Officejet 6500 wireless won't print! I have reinstalled all software and it still will not print. It tells me I have the wrong paper size (no, I have the right one in there) or it tells me out of paper, no paper is there. When it does pull paper through it does not attempt to print but the paper jams up on the right side of the printer. I have tried everything, please help! What can I do? THANK YOU!
3 Suggested Answers
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
  • 2022 Answers
SOURCE: paper jam on a officejet 6500 wireless
Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Posted on Feb 10, 2010
Cannot prink anything in black from my HP officejet 6500, have changed cartridge, colour print all ok
Check whether the cartridge's correctly installed and re-install correctly.
Clean the printhead by:-
  • Load into the printers paper tray a plain A4 sized paper.
  • On the printers control panel,press the setup button.
  • Select tools and press OK.
  • Now select clean printhead and press OK.
  • After printhead cleaning,turn the printer off and then on again.
Hope this helps.Thanks!
Oct 10, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500A Plus error message paper size is incorrect. Cannot get anything to print!
On your PC, what is the default setting for this printer. Check in the printer and accessories of Windows.
The paper size might be defaulted to A4 rather than Letter. That mismatch would cause the printer to
error out every time.
Mar 23, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp[ officejet 6500. 1: how do i print dupex ??
I'm afraid your printer is not capable of duplexing automatically, so its a case of reinserting already printed sides the other way up.
secondly the font size is set by the software you print from.
Mar 19, 2011 | HP Officejet 6500 Wireless All-in-One...
It prints on one end of the paper and not the rest of what it is to print
Check the print border settings in the printer properties page. If that doesn't help, then I suggest uninstalling the printer and software, and then reinstall in the proper order. Hope this helps.
Mar 17, 2011 | HP Officejet 6500 Wireless All-in-One...
How to print on legal size paper 8x14?
Right Click mouse to printer icon, choose printing preferences and choose paper size, choose the legal size.
Please let me know if you need more help
Mar 06, 2011 | HP Officejet 6500 Wireless All-in-One...
Cannot print on regular letter size paper on my HP Officejet 6500A Plus printer. Gives me an error message saying Paper Size Mismatch, but it is the right paper for the print job.
I had same problem. Try this: When you go to print, change your ink quality to "draft". For some reason, I was able to print after trying everything. Hope this works for you!
Jan 26, 2011 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 a plus won't print. Every time I press print, it says incorrect paper size. What is wrong?
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issues.
Nov 19, 2010 | HP Officejet 6500 Wireless All-in-One...
Connecting the HP OfficeJet 6500 to wired & wireless computers
Use the disk that came with the printer and install the software in both the computers based on the os installed in the individual computers, ping the ip address of the printer from both the computers, and then test for the functionality
Jul 13, 2010 | HP Officejet 6500 Wireless All-in-One...
My hp officejet 6500 will not print pdf files . A single blank page comes out but nothing else.
have scanned records into my computer via hp officejet 6500 scanning software. when i come to print i only get the top half of the document printed on the bottom half of the page - help!!!
Oct 27, 2009 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
123 people viewed this question
Ben Johnson
