Question about Dewalt DC930KA Heavy Duty Xrp 14.4V Drill/Driver
CAN'T REMOVE DRILL BIT. I TRIED USING A VICE, WD40 ETC. STILL CANT REMOVE
  • 520 Answers
I have used 2 channel lock pliers on both keyed and keyless chucks to break the chuck loose. just make sure you are going in the right direction. grab the chuck with one and the base with the other. always works for me..
Posted on Oct 04, 2010
The back bolt on the fuel tank spins and I'm not able to remove it. What do I do
Grab onto the side of it with a vice grip and drill out the center of the bolt. You will get it out just fine with the right size drill bit. I recommend starting a pilot hole with a small one and stepping up in size until it breaks off.
Sep 04, 2015 | Cars & Trucks
Stripped bolt on thermostat housing how to remove?
if theres any to get a hold of use mole grips and wd40. if you cant grab any you will have to drill it out using a drill bit smaller than the bolt,once your through the bolt use a screw driver to pry it off the threads
May 20, 2015 | Cars & Trucks
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
My keyless chuck has jambed on the drill bit and cannot be released. Have tried vice grips with no success. Any answers???
Try putting end in a vice and going in reverse on drill setting. If problem not resolved wd49 inbetween keyless chuck and repeat. Hope this helps
Mar 02, 2012 | Craftsman Drills
Keyless chuck has bit stuck in it
use some kind of lube like liquid wrench or wd40 and let it set for a bit. Then tap it with anything like a wrench, hammer, etc.
Feb 12, 2012 | Drills
I having problem of drill bit would like to know how to remove drill bit
Make sure the chuck is loose then clamp the drill bit in the vice and give the drill a straight pull ,once its out then put some engine oil down the chuck and let it soak in ,not that fish oil spray stuff .
Dec 02, 2011 | Metabo 600661620 SBE660 12" 01000 03000...
Stuck kohler toilet seat
most modern toilet seats are removed by opening plastic tabs on the upper rear of the seat and turning the screws counter clockwise while holding the retaining nuts underneath the bowl.there has to be access and if not ,you could drill them out from the top using a small drill bit and slowly working your way up to bigger bits till the heads of the bolts are removed.
Nov 21, 2011 | Kohler Home
How do I remove a stuck bit from the chuck?
put the drill in a vice. then use the chuck key  and a hammer to release the bit.
 if necessary use wd40 spray to free up chuck.
Jan 24, 2010 | Black & Decker 18V Cordless Drill/Driver
Chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Mar 09, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Dewalt DC930KA Heavy Duty Xrp 14.4V Drill/Driver Logo
145 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
