My Vivo TV won't turn on straight away now after a back out. It flashes blue down where the on off light is and then eventually turns on.
  • 1153 Answers
SOURCE: mitsubishi vs50605 turn on and dhuts down and light flashes 3 time
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Posted on Sep 20, 2007
  • 41 Answers
SOURCE: wont turn on red light flashes
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Posted on Mar 30, 2009
  • 105 Answers
SOURCE: my tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Posted on Apr 29, 2009
  • 40 Answers
SOURCE: ps3 turns off straight away and flashes red
it sounds like you have a short in the system. take it to a repair plase. don't try to service it your self it will disable it self if you take off the cover.
Posted on Jul 31, 2009
  • 556 Answers
SOURCE: keeps turning itself off with a red light next to
have you changed the lamp in this set. If you look by the red light it probably says lamp
Posted on Aug 07, 2009
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
Went to settings and accidently turned off blue tooth wi fi now my fire stic remote will not respond air won'' scroll up or down and I can't get back to settings
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
Apr 03, 2015 | Amazon Fire TV Stick
Remote control code required for virgin TiVo & 50 inch blaupunkt TV combo
I have just managed to do this. I cannot tell you the code as I had to do it manually, but this is how I did it.
point the remote away from the TiVo and hold down the clear button and the to button until the free light flashed twice.
type in the code 0999 and the light will flash again. Then point the remote at the to and press and hold the channel up button. You will now scroll throw all the codes.
it will take about a minute but eventually the to will go off. When this happens release the channel up button and hold down the green on button to try turn the tv on with the TiVo remote.
if it comes on press ok and this will store the code. If it doesn't come on, use the blaupunkt to remote to turn the tv back on and then keep holding down the channel up button to scroll through more codes. When the to goes off again release the channel up button and try turn it on with the TiVo remote. If it works this time store the code by pressing ok
for me it took two attempts to turn the to on but eventually it worked on the second code
Nov 29, 2014 | Blaupunkt Car Audio & Video
My Vivo ptv42hda tv makes a clicking sound when switched on but screen won't turn on how can I please fix the problem myself thanks as I'm good with electronics
do you have back light or not? and do you have sound or not?
if back light comes on and sound on but still no picture.. problem is in T-Con PCB.
if no back light.. but sound ok.. problem in back light.
Jun 02, 2013 | Televison & Video
Vivo tv won't turn on lost the remote and the
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
Jan 23, 2013 | Televison & Video
My sanyo tv odel ce37ld33-B turns itself off and blue light flashes when i turn it back on
you have bulged capacitors on the power supply board that need to be replace in order to fix the problem
Nov 03, 2012 | Sanyo Televison & Video
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Lighting was bad in my area and my tv was plugged inns surge protector the tv turned on bit the power light blinks with the opc light my dish won't how up on the tv what do u think is wrong??? I turn...
The tv have a problems with the board that called the tv main Tuner signal board.That the board where the tv incomming broadcasting signal cable plug into it.This tv it still useable.I have one too a 46".Try tv unplug,replug it back like about an hour this problems will solved for a while evenually will return though.Every times POWER and OPC LED lights flashes,just push the tv power button ON again on the remote and have to wait,sometimes tv it will lite up and work right away.Sometimes it will have POWER and OPC LED lights flashes again.Just have to push the remote power button ON again and wait a while again eventually tv it will lite up and work.Have to this like 3 or 4 times power ON button pushes somtimes,tv will eventually work though.I know i do this manytimes before my tv have this problems off/on 3 1/2 years.But finally u will have to replace the tv main Tuner signal board sooner or later though this solution dosen't work for the rest of the tv life.U can do some basic mechnical works like take things aparts and putting back together again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Turner signal board for the replacement.
Sep 02, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv doesnt always come on straight away
Need more input, what model, what brand, do it turn on if you hit the side.
Regards
What About Bob
Feb 19, 2008 | Televison & Video
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
