Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Bulging capacitor What causes the capacitor to bulge or become raised? Also, how do you take out the bad capacitors and install the new ones? Also, is there an easy way to get to them? Thanks for any help you may have. jchan@netrox.net
  • Mitsubishi Master
  • 8,617 Answers
Mitsubishi just got some bad capacitors and they end up running hot which cause them to bulge. If you are planning on doing the repair yourself I would suggest getting the service manual at the following link, as they will email it to you and they will also provide free tech support with an expert on that chassis and he will help you with the repair as special capacitors have to be installed and while your inside the set you should change any of the caps that are prone to failure. they know which ones they are and they can make the repair an easy one for you. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 31, 2008
Can a drop cause a capacitor to bulge?
Not likely. Caps are likely bulging due to heat, and are near end of life. Even if you didn't drop it, it would fail when a cap failed altogether.
Mar 01, 2015 | Power Computers & Internet
Tv turns on and off all by itself, all day long. picture is still perfect when it stays on long enough.
Good day..
That problem is usually cause of bad capacitors on the power supply section..
As you stated your TV works fine and after a minute the red light comes on...
That symptoms is cause of bad capacitors..Normally bad capacitors can check visually if the capacitors look like leak/bulged on the top that is the indication of bad one but not all bad capacitors are bulged some are not so in that case you have to used a special meter called capacitance meter..
This is the sample picture of bulged capacitors:
Hope it helps...
Dec 23, 2011 | Philips 50P8341 50" Rear Projection...
Red light is on in front and have no picture
Good day..
Dec 06, 2011 | Televison & Video
JVC 32 inch LT-32DY8ZJ T turns on...shows green light....then turns to standby then back on then off again. Can this be repaired?
Good day..
Dec 05, 2011 | JVC LT-32X575 32 in. HD-Ready LCD...
Power light becomes dim
I have discovered that this is a common problem with monitors and it is caused by capacitor failure. The capacitors in your monitor hold power enough for the display on your monitor. Inside your monitor, on the board where the power cable is connected, that is where you will find capacitors. Get any computer technician to open up your monitor and check for any bulged or burst capacitor. A malfunctioning capacitor will be identified with a bulged head or a burst. Remove the failed capacitor(s) and replace with the same type of capacitor(s) with the same voltage and degrees. Make sure that you note the polarity (-) and (+) when you are replacing the capacitors. This would help you out of your problems
Nov 21, 2011 | LG FLATRON M2900SBN 29 inch Monitor
The tv screen shuts off every few minutes.
Good day!! That problem is usually cause of bad/faulty capacitors on the power supply board..So you have a better chances and easily locating the faulty capacitors if it is look like leak/bulged on the top.. So please try to follow this instruction on how to do that.. 1. Open the back cover of your TV. 2. Look at the power supply board..Its normally connected to the power cord.. 3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors.. 4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value.. 5. Some of the capacitors not bulged so its better if have a capacitance meter.. Hope it helps you..
Sep 12, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sony tv kv g14q2 when power on it on and off rapidly
Good day!!
Hope it helps you..
Thanks for using fixya
Sep 12, 2011 | Televison & Video
No picture then powers off by itself
HelloThe power supply is dead,cause of bad or leak capacitor.If you want to fix the problem by your self you can identify the leak capacitor through visual checking.The leak capacitor have bulging tops.Remove the back cover and find the power supply,it is located at upper right.You can see the leak capacitor with bulging tops.Replace new capacitor with the same value.Hope it will help you.Thanks..
Aug 31, 2011 | Televison & Video
My 19 inch technica lcd tv won't stay on
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
Aug 26, 2011 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
544 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
