Question about Roper RGX4634KQ Gas Dryer
Can not locate belt dryer runs but tub will not turn
The belt goes around the tub and is driven by the motor which is also the blower motor. The motor is located in the bottom at the rear of the dryer. To access the belt, you first have to remove the top. To do this, remove the two phillips screws under the filter screen door. Remove the filter. The top is spring loaded to the rear and hooks in the front. To release, pull the top toward the front and lift up. You can do one side, then the other. When both sides are released, lift it up like the hood on a car. The belt is around the drum. It looks like a thin rubber band, approximately 1/8 inch thick and 1/2 inch wide.
Posted on Oct 06, 2010
Motor runs, but clothes tub will not spin, what is the problem? There is a vynyl looling inch belt on the tub.....tub spins freely with hand control.
either the belt slipped out of the idler pulley or the belt itself broke,, click on this link for easy instructions for your machine http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm please take a moment to rate my response Thanks good luck
May 30, 2011 | Whirlpool LER4634J Electric Dryer
My tub want turn, but the belt is on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 01, 2011 | Dryers
The dryer in my trailor tub wont turn I have Heat but the tub wont spin.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Mar 08, 2011 | Dryers
Dryer tub doesn't spin - motor runs and hot air comes into the tub area but the tub itself has quit spinning. Could this be the belt since the motor is running and the dryer is heating up? This is an...
Unfortunately you will have to search for thebelt with auto stores to see if any of the models will match. Check to see if any machine spares shops can help, get intouch with industriaal spares outlets to help you.
Sep 23, 2010 | Amana DLE330RAW Electric Dryer
The dryer is making a loud noise. Think its the
the belt that spins the dryers drum around has a belt tensioner located at the botton base of the body. If the roller bearing goes bad the sound you hear is caused by that. Replace the belt as well when replacing the roller or the whole tensioner if needed
Feb 06, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
The tub in my dryer quit tumbling and it's not the belt around the tub what else can i try
Hi, Does the motor run but the tub does not turn? If you would get me a model #, I can look this up and give you more instruction.
Vic
Jul 01, 2009 | Dryers
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't stay running
Sounds as if you have a belt or tub roller problem. Either can be fixed fairly easy but you will have to remove the tub. This is normally done by removing the top, then the front of the dryer. It would help a lot if you had someone to help you remove the tub.
Feb 27, 2009 | Whirlpool LER4634J Electric Dryer
Dryer tub won't turn
hear the motor running, just not spinnig drum? if so you problably eiteh threw the belt off pully it broke all together. theres 2 screws holding the front panel on apprx 10 in. up and 2in. in, slightly pointed upwards. rmeove them and the front panl comes off, i believ the top might just tip back at that pint in which case youll see the belt wrapped around the drum. ro where it should be wrapped around anyway. new belt num Y312959.if needed, youll need to reach beltto motor pulley from behind unit through a small acsess hole. be carefull not rip bag bael is in because it shows placemnet of tension pulley and correct direction to wrap belt in.anything past that, im thinkin 18 yrs has been a good run, go for new
Mar 01, 2008 | Dryers
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
41 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
