Question about Nelson Sprinkler: Traveling Tractor
Broke off one side of the sprinler arm. - Nelson Sprinkler: Traveling Tractor
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
Why wont the rocker arm go up or down on left side of my generator and how do i fix it.i replaced the rocker arm on that side it was broke .the bolt was broke
Several reasons why an OHV rocker won't work.
  • Push rod not installed in the lifter.
  • Stuck valve
  • Valve guide work loose jamming valve movement
  • Bad cam lobe.
Are just a few possibilities.
May 29, 2015 | Electrical Supplies
Broken Water Dispenser Arm - GE Monogram Side-by-Side
First, what is the entire model # from the sticker inside the fridge section?
Nov 11, 2007 | GE GSS20IEP Side by Side Refrigerator
Drivers side wiper arm fell off of 2004 chevy malibu
try ebay there will be a few parts on there.
Mar 09, 2014 | Chevrolet Cars & Trucks
Rear wiper arm broke took nut off and the piece of old arm that broke will nut come off
Hello plong.
Couple of ways to remove the arm off the taper fit.
The best way is to use a puller designed to do the job. This may need to be purchased at a good automotive tool supplier.
Or if you would like to try it with out the tool, place the face of a large hammer on the outside of the arm and then tap with a smaller hammer on the opposite side. This will vibrate the arm and break the taper....But if the assembly goes through glass you run the risk of breaking it if you hit too hard or slip.
Another option is to cut the old arm through the same direction as the wiper motor shaft using a tool such as a Dremel with a metal blade.
There are a couple of suggestions for you.
Thank you for using FixYa.
KL
Mar 01, 2011 | 2008 Lincoln MKX
When I turn on the dishwasher there is no water coming out of the sprinlers that rotatae
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 03, 2011 | Whirlpool Dishwashers
The windshield wiper arm on the drivers' side of my 1999 S10 went erratic. It is all over the place. The passenger side is fine. Need help fixing it. Thanks
At the base of the arm there will be a plastic cap. Pull up on it and there will be a nut that holds the arm to the wiper linkage. It is usually a 15mm or 13mm. With the arm in the proper place tighten the nut. That should take care of it.
Oct 01, 2010 | 1999 Chevrolet S-10 Pickup
Wiper issue
wiper arm bolt needs to be tighened, or more common the arm needs to be replaced. where the bolt is the end arm insert is made of soft led as to strip out if arm becomes binded by snow, tree branch etc so the more expentise linkage or wiper trasmisson, or motor do not become damaged.
Dec 31, 2009 | 1999 Buick Century
The emergency brake pedal will not lock down when engaged and the release is sticking outward like the cable has broke somewhwere in the system and lost its tension. Is the cable broke or is there another...
make sure you clean and oil e-brake arm, the spring might have broke, or little lock arm could be sticking . put wd40 all over asembly, any moving parts, you might have to move lingage on side back and fourth to loosen up start there. good luck.
Oct 14, 2009 | 2001 GMC Sierra Crew Cab
Broken hydraulic arm on rear hatch of 2000 Chrysler T & C
if the bolt itself is broke try getting it off with a pair of vice grips if the bolt sticks out enough otherwise you could take it to a welding shop and have them weld a nut onto the bolt so you could get it out and go to the dealer and buy a new one.
May 29, 2009 | 2002 Chrysler Town & Country
Nelson Sprinkler:  Traveling Tractor Logo
99 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
