Question about Panasonic SC-HT1500 System
Unformat when i first turn on the dvd player it does its self check then says format disc,but it wont let me say no to format so i have to put in yes then it says formating failed then just freezes and wont do anything at all...unformat reads on the front window and thats it, it wont do any more so i have to press and hold the standby button for it to switch off...so annoying as it was working fine one day then nothing the next...the unit is 3-4 years old...thanks very much...russ
  • rustyno8 May 28, 2008
    thanks but its the hard disk its trying to format all the time not a cd or dvd thats in the player itself cheers
    Problem Solver:
  • 6 Answers
Check your compact disk if it is pirated.or just clean the dvd by the use of the lens cleaner
Posted on May 28, 2008
How do I format an unformatted disc?
Unless it is a read/write disc, you will not be able to reuse it. If it is read/write, you will see the letters RW on the disc. You could put it in the computer and try and format it. Make sure that you format it and not another (hard) drive or USB on your system, because you won't be able to get the information back from a formatted disc.
Good luck,
Paul
Dec 26, 2015 | Televison & Video
Wont idetify blank disc and wont format
This unit is designed to work with DVD-R, DVD-RAM and other discs as listed in the manual. You don't need to format discs for them to work in this machine. Just put the blank disc in, and record something to it.
Oct 01, 2013 | Panasonic DMREZ27 DVD Recorder
I have a Toshiba DVR620ku DVD/VCR combo. I have the Format Mode properly set to "Video mode." I put in a new, unformatted DVD-R, and the player should format the DVD, but it doesn't. I click...
My brother had the same problem. Toshiba tech support said the disc was already formatted, so the DVD MENU option would not be available. He went straight to dubbing and recorded to the disc. After recording, the DVD MENU option was then available. He thought the disc was not formatted since it was straight out of the package and he always had to format other new discs. Perhaps your disc was actually already formatted?
Oct 27, 2010 | Toshiba DVR620 DVD Recorder/VCR
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unformatting
yOU CAN'T UNFORMAT, BUT YOU CAN REFORMAT DIRECTLY FROM THE PLAYER
To format the player directly, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Settings from the Main Menu.
3. Select System Settings.
4. Scroll down to Format and select it.
5. Select Yes to start formatting.
Aug 31, 2008 | SanDisk Sansa m240 MP3 Player
Panasonic DVD Recorder/Player - DMR E51- not able to Record
i do not have this problem however recently my DVD simply would not turn on, i unplugged it for a few minutes and it now works. my complaint right now is that one of the discs is now coming up as unformatted and when i try to format it, it cannot be done. the other 2 discs are fine (as this one once was also!)
Jan 02, 2008 | Televison & Video
Permanent Disc Protection
Hi, UnFormat Problem 1. Try Panasonic DVD-RAM, format that on the recorder, donot finalize OR 2. Try this http://www.videohelp.com/forum/archive/repair-guide-for-panasonics-dmr-e60-gh-quot-unformat-quot-error-t299504.html There is a jpg image on the above URL for guidance Hope your problem vanishes :) Moulee mbchandru@gmail.com
Aug 03, 2007 | Panasonic DMR-E75V DVD Player/VCR
Panasonic SC-HT1500 System Logo
131 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
