Question about Lexmark X4270 All-In-One InkJet Printer
Error 1200 i have tried to unplug then pull the cartridge to the center. I am still unable to pull the cartridges to the center. please help
  • DeeBeaup May 30, 2008
    The printer cartridges are stuck to the left and I cannot move the brown feeder at all, any suggestions?
  • Anonymous May 30, 2008
    marca error 1200 y no se que tengo que hacer ya que el manual se extravio
I keep getting the error 1203 and i unplugged it and did what it said about removeing the cartridge twice the way they said but doent take care the problem and it says to consult my guide but can't find it
Posted on May 30, 2008
  • 426 Answers
Turn on your all in one, open up front door and your cartridge door, slide brown and black belt (it has little grooves on it) to the left carefully till you can take out both ink cartridges, take them both out, snap them both in, then slide cartridge belt back to the right, close doors, turn on
Posted on May 27, 2008
Error 1200
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Feb 08, 2012 | Lexmark X Office Equipment & Supplies
X4270 error 1200
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.By trying physically pulling the carousel to the middle (NOT BY THE RIBBON CABLE) ,if you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.Your problem is fixed.
Aug 27, 2009 | Lexmark X4250 All-In-One InkJet Printer
1200 error
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
YAY problem fixed.
Hope this might helpful to you.
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error #1200
if that doesnt help...
remove the shell from the black base, clean the goop from under the ink cartridges, put silicon on the bars after cleaning with alcohol, grease the gears sparingly, put it back together,
good luck
Jul 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error Message
Mar 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error #1200 still
Your cartridge slide is jammed. try moving it about 1/4 inch manually.
Oct 05, 2008 | Lexmark X4270 All-In-One InkJet Printer
My message window shows error 1200. What does this mean? I cannot find a solution in my trouble shooting guide
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
Try this first step to correct it
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay. if the error still persists Could be a timing belt issue, gearing or a jam, etc.
Typically, Dells are Lexmarks...
If you're comfortable with a wrench, have a look here:
http://support.lexmark.com/cgi-perl/...ocid=ENUS23485 .hope this solves your problem .appreciate by rating this as fixyaa
Sep 30, 2008 | Office Equipment & Supplies
Erropr code #1200 Lexmark X4270
Tried what blkghost suggested above but had to tweak his advice slightly.
YAY problem fixed.
Nov 02, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
