Question about SanDisk Sansa m240 MP3 Player
PROBLEM WITH SANSA M240 MP3 PLAYER
Even my sansa has the same problem.When I try to switch on my sansa mp3 player,it gives the message 'NOT ENOUGH SPACE, PLEASE EMPTY 8Mb'.Even my computer does not detect it.Please suggest some solution to this.
Please suggest a solution.
Sandhya
Strak mp3 playare
Posted on Nov 20, 2008
  • 8,596 Answers
Needs to be reformatted and firmware upgraded - corrupt DB
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
Not enough space? sansa m240
try formatting the device..that must solve the problem...if it doesnt,use sansa updater to update its firmware
Sep 07, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240 not being recognized, even after changing to msc
try this it is a driver for that specific MP3 player also if that download don't work search of Sansa M240 driver and other sites should be available for that driver to download
http://www.drivers.mrjuan.com/driver-5953-sansa-m240.html
Just select your operating system of course its XP download should start up hope this is helpful!!
Jul 26, 2009 | SanDisk Sansa m240 MP3 Player
I missed the sansa m240 software so iam looing of the sansa m240
You can download the software from the manufacturer's web site at http://www.sansa.com
Mar 17, 2009 | SanDisk Sansa m240 MP3 Player
Formatting sandisk sansa m240
how to download songs and delete the songs
Jul 05, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m240 can't work
try formating the player when connected to the pc. and then get the firmware re flashed.. hoping u have not tampered on it's board.... and contact the sansa care from its website.. all the best..
Jan 24, 2008 | SanDisk Sansa m240 MP3 Player
PC not recognising hardware
I have had the same probmlem but I've begun to realize that windows vista isn't compatible for the MP3 player when I tried using it with Windows XP -- and it worked fine.
Jan 07, 2008 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
Sandisk sansa problem
This error message may largely be due to the corrupted Music Database file that the Sansa M240 creates to maintain an information pool on the music files downloaded to it. Normally, if you are unable to completely format the player in Windows Explorer, there are still 2 other (and actually, more recommended) options that you have: (1) Switching the M240 to MSC mode and formatting in "Disk Management". You can get to this window by right-clicking the "My Computer" icon and selecting "Manage". Make sure that you use the FAT file system to optimize the 1GB memory (2) Switching the M240 to MTP mode and formatting the player in Windows Media Player 10 or version 11. The mode of the M240 can be changed by accessing the menu and going to "Settings", then choosing "USB" In general, formatting the player in "Disk Management" is more effective than formatting it in Windows Explorer. Also, it would be a good idea to upgrade the player's firmware to the latest version via the SanDisk website: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 I hope this helps. The M240 is a great player.
Apr 20, 2007 | SanDisk Sansa m240 MP3 Player
My Mp3 player does not plug and play properly in my Xp computer
Youmust have instaled MEDIA PLAYER 10 , oderwise your computer will NOT see the device
Mar 07, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
