Question about Sony Audio Players & Recorders
I have an Sony CMT-HPX7. The volume knob does not function properly. After a lot of turning it will occupationally change the volume, but in whatever direction it feels like. I turn it clockwise and the volume goes down, or if I'm lucky, up. Same thing counter clockwise. Thank you
  • 67 Answers
SOURCE: Barista Coffee Grinder
Turn the knob back the other way, while the grinder is not running! This should free the burrs, if necessary then, dismantle, clean and replace.
If, when the upper burr is unlocked from the lower, the motor will still not run, you have done worse damage.
Posted on Mar 14, 2008
marsrover
  • 682 Answers
SOURCE: volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Posted on Jul 05, 2008
toddg
  • 171 Answers
SOURCE: Honda Civic Issue with Radio Volume Control
This is a known problem with the factory units and no, there is no fix. There is a series of checks you can do, but short of that the only option has been to replace the unit. I have included the graphic for the checks, other than that it is not fixable.
Posted on Sep 24, 2008
SOURCE: volume problem with VSX-D409
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
Posted on Jun 02, 2009
SOURCE: removal of cycle time knob waching machine whirlpool lsr5233a
push knob in ,with the front panel unscrewed lift up to back side of the knob,there is a black plastic pin in the center of the knob.pull the pin out and it releases your knob
Posted on Aug 13, 2009
Technics 1080 pre amp volume control is not functioning correctly
Technics SE CA1080 Service Manual
there is a chip called an operational amplifier under a heat sink on the pcb,that fails when it get top volumed for two long theres regulators with heatsinks.
it is listed as,
Technics SE -CA1080 amplifier F61 fault,
May 13, 2015 | Technics Audio Players & Recorders
Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Aug 13, 2012 | Sony CMT-GP5 CD Shelf System
How do I set clock on dpx308u
See pic below for reference. Press SRC button 4x to get to standby mode. Press "Boost," for 2 secs. Use volume knob to change hour. Press volume knob when hour is reached. Turn volume knob to set minutes. Press volume to set time. All done. Press SRC button again to go back to your tuner, or CD, or whatever.
Mar 08, 2012 | Kenwood Car Audio & Video
Sony CMT-hpx7 - CD changer is stuck with 2 CDs inside. Any ideas how to open it without destroying either the CDs or the stereo? Any help would be appreciated!
it a bit complicate to open
you can try but you need to remember what you open so you can put back in the same order
try this
first open the back cover you should be able the see the inside then you need to open the top cover now the changer can be open without power you need to locate the motor and turn the the belt or the wheel slowly and it wil take the disc out. """"""dont turb back""
you need to plug the power and let it go back alone after that disconnect the power and put back everything
its not so easy so before you do it make sure that you can open and put back
Hope it will help
Aug 24, 2010 | Sony CMT-HPX9 CD Shelf System
How do you change functions to get to the audi in function
Press the FUNCTION button on the RM-SC30 remote that should have been included with your Sony CMT-NEZ3.I have not found a way to select Audio In without the remote. See http://esupport.sony.com/US/perl/model-home.pl?mdl=CMTNEZ3 to download your manual.
Jan 15, 2010 | Sony CMT-NEZ3 Shelf System
Change input to Aux In without remote CMT-NEZ3 Sony
I have not found a way to select Audio In without the remote (and I've tried every combination of buttons I can think of!)
The approved way to select Audio In is to press the FUNCTION button on the RM-SC30 remote that should have been included with your Sony CMT-NEZ3. See http://esupport.sony.com/US/perl/model-home.pl?mdl=CMTNEZ3 to download your manual.
Dec 11, 2009 | Sony CMT-NEZ3 Shelf System
DEFECTIVE MANUAL VOLUME CONTROL ON SONY CMT-HPX10W
remove knob and use some pressurised air to blow out any scum thats built up. yes a remot would still work.
Jun 02, 2009 | Sony CMT-HPX10W CD Shelf System
Sony CMT-NEZ30 no sound, goes to standby
Check your speakers maybe one are about to burn out
Jun 26, 2008 | Sony CMT-NEZ30 Shelf System
For My Sony CMT-HPX9 [mp3]
Plug the cord into the headphones/mp3 port on the front and press function until the MD option pops up. It should work then.
Oct 27, 2007 | Sony CMT-HPX9 CD Shelf System
Sony CMT-CP101 No volume
There are many things that could cause problem. One could be the volume control and/or PC board may be cracked or have cold solder connections
Oct 20, 2007 | Sony CMT-CP101 CD Shelf System
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
