We don't use our typewriter very much anymore and when I do it is when I am on a tight schedule typing up a bid package that I need the decimal tab for.
No one can remember how to set this - can you help?
Move to the position you want the tab, hold down the tab set key and the mar rel key the display will show an arrow above the decimal. to use tab to the position type number with the. then tab the number will print with the dec. lined up.
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
I assume you are talking about Flush Right Tabulation.
To set a flush right tab:
(1) Position the carrier (or cursor) at the point where you want a flush right tab to be set.
(2) Hold down the Tab set/clear key and press the 2 key.
To clear a flush right tab:
(1) Press the Tab/back tab key to move the carrier (or cursor) to the flush right tab position.
(2) Hold down the Code key and press the Tab set/clear key.
To use a flush right tab:
(2) Type the text. Characters will appear on the display as they are typed. Corrections can be made on the display before the text is printed.
(3) Press the Print key. The text is printed aligned with the flush right tab position.
To find out more about your Swintec 7040 typewriter, you can buy a PDF manual for only $10 at:
My best guess is that you have the R. margin set there. Go to the stopping point, press but don't hold the MAR REL key, spce to desired location, press R. mar key.
The code key works with all the keys in the top row to set up those functions, bold, underlind, KDII, etc. The function allows you to type on the display befor printing.
Space all the way to the right press and hold the tab clear ket, press return, all the tabs should clear.
Space to the points that you want tabs and press tab set.
To clear an indivual tab tab to that position and press tab clear.
DickyO
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
First check check the pitch selector switch to be sure it is not in proportional spacing. if it isn't push down on it and see if it goes away, if is goes away the keyboard needs repaired.
Thanks - I appreciate your help.
580-765-7810
