Question about Magic Chef Microwave Ovens
Turntable no longer turns not getting full power
  • Magic Chef Master
  • 8,864 Answers
Are any other appliances or light bulbs giving you trouble?
I would want to first make sure that your power line voltage was correct.
Or, when you say "not getting full power" does that means it's not heating as well?
That's quite possible, since the turntable is essential to even heating.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
Please write back with your brand and model number and more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2008
Oven turns on but no longer heats.
The inverter board (power for Magnetron) and some have a large diode that also fails===so possible are the diode, the inverter board or the Magnetron itself.
Dec 04, 2012 | Microwave Ovens
My sharp R-340H no longer cooks. Still powers up
Please check the door safety interlock switches ...
If the switches are faulty, the oven thinks the door is open and will not turn on the heat ...
Find them indice hear the latch assembly.
Jul 09, 2010 | Sharp R-340 Microwave Oven
The turntable no longer turns
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can find helpful exploded view diagrams and order parts for most major brands by entering your full model number from the tag on the oven here.
If you don't find what need there, you can probably order parts from Encompass here or you can call them toll-free at 866-779-5835.
William E. Miller
prototech@usa.net
Aug 26, 2009 | GE JES1851 Microwave Oven
Spacemaker XL1800 turntable turns sometimes
I would say an internal post broke inside the motor. This often happens when a heavy item is placed on the tray.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No longer turns
on the bottom of most units you can get to the turntable motor with some side cutters,cut the joins. pull the little flap off and there is your motor run a current through it to see if it turns(how much will say on the motor) if not turning there is your problem
Oct 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Samsung microwave no longer spins. Any ideas? Please help
You can order Samsung parts here.
Aug 19, 2008 | Microwave Ovens
I can't get my clock set. I push options, 3 and 1, then when I put in the time, nothing happens. I need to know if I can use a ceramic turntable out of my old Microwave Convection oven. My oven...
In case your owner's manual is missing, you can download it here.
If you're still having trouble after consulting the manual, please reply back.
The ceramic turntable (actually ceramic coated metal) will be fine as long as it doesn't have chips or cracks where arcs can occur.
Also, for even heating and longer turntable life, don't place your food in the center, but slightly off-center instead.
If you need to order a new turntable, enter your full model number JES1290SK here http://tinyurl.com/gv383
May 08, 2008 | Microwave Ovens
That would be the turntable coupler.
For more help from Emerson : http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Nov 25, 2007 | Microwave Ovens
Turntable roller rest
It's called either the turntable coupler or the turntable support, depending on your model number. You can visit the Sears parts Web site at http://www3.sears.com/ and enter your full model number and see exploded view diagrams, parts lists, and order the part. Or you can call Sears parts at 1-800-252-1698.
Mar 24, 2007 | Kenmore 62463 Microwave Oven
Your problem is either a weak or slipping motor or a broken / cracked turntable coupler. If the coupler turns loosely without actually engaging the motor, it is bad. If the coupler is good or looks good, it's probably the motor. One test of the motor is to firmly grab the shaft with pliers and try to gently turn it. It should turn with some resistance and make a whining sound as it turns, since it is a highly geared motor. If the motor turns very very freely - or not at all - then it is bad. You can see an exploded diagram and order parts via the Jenn-Air (Maytag) Web site at http://services.maytag.com/abs/PartsStore.do?nextPage=psstartpage You will need to enter your full model, which is apparently one of the following: JMC7000ADB JMC7000ADQ JMC7000ADW Referring to the CABINET-BASE-CAVITY diagram found there, you will see: - REF 23 motor - REF 27 coupler One of those is likely the culprit.
Dec 06, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
