Question about Brother MFC 8300 Laser Printer
Cannot receive faxes, and machine still says to replace drum after installing a new one.
  • 48 Answers
You can manually do a drum reset:
Open the front cover. Press the CLEAR/BACK button. Press 1, when the display shows accepted close the cover.
Posted on Oct 04, 2010
Our fax machine has been saying replace drum for a while and faxes have been getting darker and darker we cleaned it but now we can send but not receive what is the drum?
the drum is green roller in housing with toner, you should order the drum cartridge for your fax. With new drum you get the how to manual also. Follow the procedure.
NOTE THAT THE DRUM UNIT IS SEPARATE FROM TONER UNIT.
Hope that helps!
Oct 19, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
New drum
It is important that you replace the drum when the machine is saying "REPLACE DRUM"...NOT when it is saying "REPLACE DRUM SOON".
When the machine says "SOON" it is advising to have a drum on-hand ready for replacement. The machine will still be able to print pages. When the machine says "RPLACE DRUM" it will no longer print and a new drum cartridge must be installed to reset the indicator.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
New drum
You need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 25, 2010 | Brother IntelliFax-2820 Laser Fax
Sharp FO-4470: Error message is: "check cover or drum"
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Apr 23, 2010 | Sharp AR-F152 Fax
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
"DRUM LIFE OVER" KX-FL511
just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Dec 31, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother MFC 8300 Laser Printer Logo
53 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
