Question about LG Cell Phones
Phone won't switch on. we've tried everything in the manual but it still doesn't want to switch on.
  • son74 May 27, 2008
    my lg prada KE850 turned off by itself and won't switch back on. it makes a buzzing noise everytime i hold down the on/off button. could anyone please help with this problem?
  • ianphillips2 Nov 14, 2008
    3 times i bought a new prada phone as mine wont switch on, at £230 a time its getting expensive, it seems to work for around 3 months then it will do this, i have now bought a different phone as i cannot have an unreliable phone, i really like the prada though as it is really light and slim, but i dont like getting dissapointed everytime it breaks. i think i need help off someone who knows why this is happening.
  • 549 Answers
Check out some answers here
or copy and paste
http://forums.mobiledia.com/topic55429.html
Posted on May 27, 2008
2008 Jeep Liberty
Possible solution - This happened to me and my battery was dead in my key fob and also I needed an ignition switch because a piece on it was broken which therefore wouldn't turn to start the engine.
Apr 26, 2013 | 2008 Jeep Liberty
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Ok, I have a Zhone 6211-I3-200 Bridge/Router or in other words a Paradyne ADSL CPE, and I cannot for the life of me get it to work with my Xbox 360. I used to have a different router and I would switch...
Zhone Modem Model #. 6211-13-200-0PA ADSL2 BRIDGE/ROUTER, AN.
I would like to upgrade current Firmware, but it is quite difficult and my ISP support even knows how to do this upgrade.
Nov 06, 2011 | Zhone 6211-I3-200 Router
I'm following the instructions on my Whirlpool range to clean the oven. I've done everything the instructions said, but it won't get going. ( set the knob to clean, set start and stop knobs...
Might be a typo in the manual typically the latch is moved to the right to close and after clean is over move to the left to open. BE SURE TO REMOVE RACKS BEFORE CLEANING
Aug 11, 2011 | Whirlpool Ovens
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
Battery is brand new, connection is good at the battery. All fuses are good. Turn key on and nothing happens. We ran a wire from the postitive side screw on the fuse box to the pos lead off the battery and...
You've checked the connection from the fuse to the batterie but have you tried to bypass the keyswitch, it could be the switch doesn't connect inside or the key doesn't turn the switch inside.
Jun 11, 2011 | 1987 Suzuki GV 1400 Cavalcade GT
Cannon Speedlite 270EX doesn't turn on and I put new batteries in
Try cleaning out the contacts where the batteries touch. Make sure the battery door is completely flush with the body and see if you've inserted everything correctly. The type of battery you use also effects the flash recycle time and how it operates too. Have you tried using different types of batteries? Try using NI-MH instead of Alkaline and see if the speedlite will power. There's a test button on the flash and also an off-on switch you can try toggling around. The flash itself is very simple so if it still won't power on after all of that, you should contact customer support.
  • http://www.usa.canon.com/cusa/consumer/products/cameras/speedlite_flash_lineup/speedlite_270ex#ServiceAndSupport
May 17, 2011 | Canon Cameras
Cell Phones Logo
21 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
