If my PC and wireless router are in sepperate rooms (because of cable) where do I hook the USB to? I just got the road runner wireless kit.
  • 19,396 Answers
Hi Edwards.
Most routers can be configured either using a USB cable, or the Ethernet cable (RJ45 terminated with square shaped connector).
Check the kit instructions, and find out if there is a procedure to do setup using the ethernet cable.
If instead you have to connect USB cable to the wifi transmitter, and transmitted is attached to the router, you need to connect a laptop to the transmitter to configure the transmitter, and then configure the PC to control the kit.
If that does not work, regarding the Road Runner kit, I could not locate the model, maybe more info on model number and manufacturer of the kit can help (eg seller URL, or manufacturer web address from instructions). Try giving me kit and router info if the above does not work.
Posted on Oct 04, 2010
Service Hook-ups...
1- in order of what connects to what
1- linksys connects to road runner modem. Should be a network connection on the back of the router that says uplink. This connects to the road runner`s wired port on the back of the unit.
Vonage phone will/should connect through the wireless section an in your personal wifi connection when you get the router wireless setup. Name your wireless something that other people are not using and then tell vonage phone to connect to that network.
Hope this helps
Feb 16, 2014 | Linksys E3000 Wireless Router
I just put a pc in my room and got a wireless router because i have a pc in my living room already hooked up to the internet. i tried to hook up the wireless router and get a connect but now the my pc...
try to check the the network cable.there is something wrong in your cable.maybe wrong setting of wires.but you said you got wireless router right.why go on wireless..much better you buy a wireless USB connector.less maintenance.if you prepared wired..this is the setting of pins of network cable.8 pins each RJ45 both ends. 1.stripe orange 2.orange
3.stripe green 4.blue 5.stripe blue 6.green 7.stripe brown 8.brown
Jul 15, 2011 | Computers & Internet
I only have one PC in my house and it's not in the same room where the cable outlet is located. Right now I have a very long coax cable running from my cable modem to the cable outlet in the other room. Is...
Purchase either a USB stick that adds wireless capability to your laptop/desktop, or purchase a PCI wireless adapter-card for your desktop, and install it.
Then, you can move the cable-modem much closer to the cable-outlet, and then connect the cable-modem to a newly-purchased wireless-router ($20 to $70) to receive/transmit over your in-home wireless network.
Jan 24, 2010 | Gateway GT5654 Desktop PC
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
I have roadrunner internet and when i connect it directly to the main desktop computer it works fine but when i put it through a linksys router the internert doe snot work and the rest of the computers in...
You need first to configure the linksys router to work with your road runner cable internet, if you have the setup CD for the router you can use to configure the router but if not you need to manually configure the router to work with Road runner cable internet by accessing the router setup page, if you're not aware on how to manually configure the router to work with road runner you can call this number so a Tech can walk you through with the process 1-877-787-8749...
Oct 16, 2008 | Computers & Internet
Connecting a router so I can use a second desktop pc
In addition to a wireless router you will need a wireless reciever for each PC you wish to have working simultaneously (assuming the PC does not already have a wireless networking capability) .
The wireless receiver is usually a USB or laptop PC slot device which you plug in to the PC and after installation of the necessary software (usually supplied with the device) you can surf wirelessly. The USB type wireless devices are about GB£20 to buy .
Jun 11, 2008 | Linksys Wireless-G Broadband Router
Ipod touch and road runner
try to reset the Network from ipod
choose Settings > General > Reset > Reset Network Settings.
Damn sure it fix trust me
May 04, 2008 | Apple iPod touch
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
Router
I usually don't use the software, I use the default IP address of the router to log into the router and set it up. Manual
to enter the routers utility,plug the pc/laptop into the router with the cat 5E cable, open the browser, type in the routers address,
192.168.1.1 User is blank password is Admin.
software.from this link, choose which wrt54g you have version 1-7
Apr 01, 2008 | Linksys Wireless-G WRT54G Router
Not working on my 2nd computer
I am going to assume Vista is the first OS and both machines are windows computers and you are accessing the cable service through a DI-524 wireless router. There are many issues that can relate to your problem. First does your cable provider require you to logon to access the internet. If so, try using each computer individually (with the other one logged off and shutdown) with the existing wireless connection. If this works both machines are configured correctly for the router and the issue appears to be dealing with the logon possibly having it performed by the router if possible. Second if that does not work -- on each machine bring up a command prompt window (Start > All Programs > Accessories > Command Prompt) and type ipconfig and press enter. There may be multiple local area connections but look for one with a 192.168.?.? address on each machine. The first question mark should be the same on both machines and the second different. If this works both machines have connected to the router and we are seeking another issue. If this is not true one machine has a configuration problem and cannot access the wireless router (probably the Windows ZP computer from you description). We will need to diagnose further once you answer the above questions.
Dec 05, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
