Question about Acer NSK8458AN Keyboard
Curser is set to move by the arrow keys. how di I get it to go back so I can move it through my keypad
  • 34 Answers
Most probably you accidently hit the scroll lock button.
press the scroll lock button again.
-----Original Message-----
I must have hit a control function. Now instead of
moving up/down/left/right
in
individual cells, I am moving the whole page. Any Ideas?
Thanks
Ike
Posted on Oct 04, 2010
I have a Dell Studio Laptop. I have to move the curser at the right hand corner to scroll the page?
Find your way into control panel and check mouse settings I believe the middle mouse button is adjusted there. The details are different with each brand of mouse but this should point you in the right direction.
Jun 17, 2014 | Dell Studio 15 Laptop
When i click the enter key, my curser moves half way down the page, not to the next line
tolong boss di bantu ' saya lupa id user name poker 88 saya ' smntara uang sudah saya transfer k nor rekening 6470353374 atas nama denis ' sebesar 100ribu ' nama rekening saya Mulyadi nor rek : 8375097831 ' tolong boss di bantu
Sep 30, 2013 | Yahoo Mail
Gateway MX6124 laptop: some keys on the right side of the keyboard display numbers instead of letters. Keys involved and actual display are: Row Starting with q: u=4, i=5, o=6, p=*, Row Starting with a:...
Your computer is in keypad mode. To check, turn off your Num Lock. On my system that disables the embedded keypad. To fix, go into setup (usually F1, F2 or delete when booting). Somewhere you should find a setting for using the embedded keypad. Mine has two options, Fn Key Only and By Num Lock. Yours may be different. One activates the embedded keypad, which you are seeing. Try the other setting.
Apr 25, 2010 | Gateway MX6124 Notebook
Why does my curser keep moving to the top pf the screen and then willnot move for for a couple of minutes then work again for 20 secs and then move back to the side of the screen? please help
To resolve this problem, disable the SnapTo feature, and then download and install the updated pointer files from the Microsoft Download Center. To do this:
  1. Press CTRL+ESC to open the Start menu.
  2. Use the UP ARROW key to select Settings, press the RIGHT ARROW key to select Control Panel, and then press ENTER.
  3. Use the ARROW keys to select the Keyboard icon, and then press ENTER.
  4. Press SHIFT+TAB, press RIGHT ARROW, and then press RIGHT ARROW to select the Pointer Activity tab.
  5. Press TAB three times, and then press SPACE BAR to clear the Snap pointer to default button in dialog boxes check box.
  6. Press TAB twice, and then press ENTER.
  7. Close Control Panel.
  8. Download and install the 11p32upd.exe file from the Microsoft Download Center.
    NOTE: After you install the 11p32upd.exe file, you can use the Mouse tool in Control Panel to enable the SnapTo feature.
The following file is available for download from the Microsoft Download Center:
Collapse this imageExpand this image download.gif Download 11p32upd.exe now (http://download.microsoft.com/download/easyball10win/update/1/win98/en-us/11p32upd.exe) Click on this link if all else fails: http://support.microsoft.com/kb/175400
Mar 17, 2010 | Toshiba Tecra M1 PC Laptops
It will not turn on and has new batteries
Hi:
you need to check the brightness setting. press the 2nd key and press and hold the up arrow key or the down arrow this will darken or lighten the screen so you can see the curser along with your numbers
Oct 08, 2009 | Texas Instruments TI-84 Plus Calculator
The numbers are not visible on the screen and Im not able to set the calculator on the degree mode .
First try this- press the 2nd key and press and hold the up arrow key or the down arrow on the right side of the calculator a for a few seconds and see if the curser appears - if it does - than problem solved . to set the calculator to degree mode press the MODE button and find Radain, degree and hightlight it by moving the curser over it and press enter than exit it now set to degree and press sin(30 and enter and see if you get .5 as a result it it does than problem solved
Oct 06, 2009 | Texas Instruments TI-85 Calculator
Acer 1690 keyboard arrows problem
Sounds like your number lock maybe be on. It could also have a shortcut function option that is on. If not, have you spilled anything on it lately?
Mar 22, 2009 | Acer Aspire 1690 Notebook
Changing Movie Recording Pixels
I phoned canon customer service. They said that you must turn the dial around the function set key. It will then change the movie mode from compact to standard ... and then you will be able to change the resolution. When I did it, the resolution went back to 640, which is the resolution on which I had it previously. Well before the compact mode issue.
Yannick Jeggels
Aug 02, 2008 | Canon PowerShot SX100 IS Digital Camera
Ringer
You must go into programming to set this phone to ring.
The first thing that you have to know is , the group that all of your calls ring to. This is the 5xx # that shows on the display when the call is ringing in . (i.e. call for 500) 500 is the default ring group.
to enter programming, go to any display phone, without picking up the handset.
press transfer
dial 800
Passcode = 4321
press "1" (enable)
press speaker
dial 600
use the volume arrow key and arrow up until you get to
Members .
Press the right softkey under the display just to the left of the scroll btn.
the curser will move over under the member # (i.e. 01)
use the arrow up key to go to a member # that say NONE to the right of it.
press the right softkey again and the curser will move over and then dial the ext # that you want to ring and press the right softkey again.
press transfer to exit programming
the phone should ring , if you find that the ext is already in the ring group, then there must be a btn on the phone that you can press to put it in/out of the group.
Mar 19, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Acer NSK8458AN Keyboard Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
