Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Aggitates but does not spin out to rinse
Washer will not spin out to rinse on normal cycle, the water just sits in there (the lid is shut). Sometimes will spin out and run through on delicate cycle. Or I can move the dial to the casual wash or Extra wash to have it spin out and it might. Any ideas?
  • 525 Answers
From the description of your complaint, I would replace the timer to correct the malfunction.
Posted on May 27, 2008
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Rinse problem
Sounds like a timer issue. Try this, Yes it sometimes works. Spin the timer knob vigorously six to ten complete turns. It may be that the contacts are stuck together and this frequently frees them. Timers are expensive, so this is worth a try. Good luck.
Jul 01, 2009 | Kenmore 22642 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Machine wash ,but will not rinse or spin
You have a broken lid switch. Assuming you have the same style washer. The switch is #11,
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 12502 won't spin
The lid switch is broken......
Oct 05, 2007 | Kenmore 12502 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
302 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
