Question about IBM Infoprint 1332 Laser Printer
Hello I am getting a paper jam error #241 "check paper tray 1 "
  • IBM Master
  • 1,684 Answers
Error 241 indicated the printer was not able to pickup and pull the paper into the unit. This is caused by worn pickup rollers. The rollers are user replaceable. If you pull the paper tray out and look under the printer you will see the pickup assembly and 2 rollers , one on each side. When these rollers get worn down they can not pick up the paper correctly and you get the 241 error. The part number for the rollers is 99A0070 and you can get them here:
http://www.ccl-la.com/catalog/product_info.php?products_id=94
I hope this helps,
BuddyMc
Posted on Aug 21, 2012
  • 231 Answers
DEAR SIR,
Some print media, although they may conform to size and weight specifications, may not perform to your expectations. Print quality, jam rates, fuser life, and output stacking can be affected by the printing environment (temperature and humidity) and characteristics of the paper (structure, moisture content, smoothness or thickness);
Duplex printing is not supporteD
Using Auxiliary tray is recommended
HOPE THIS HELPS....
Thank you sir,take care
Posted on Oct 04, 2010
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
My Lexmark C510 keeps popping up with a Paper Jam 241 error in Tray 1. There is no paper jam. I open the printer door take the tray out, put it back in and shut the door. How can I fix this problem? I...
I have a Lexmark C510 colour printer: Manufacture date June 2005.
I had been getting the "Paper Jam 241 error in Tray 1" message for some time. Sometimes it would print just fine but in the past several months, it's been bad. I'd pull the tray out (notice roller marks on the top sheet that was only partially fed), reinserted the sheet properly into the tray and try again and again. The techy at Lexmark mentioned that I could purchase a new rubber roller that feeds the sheet but that I might first wipe down the roller myself as they get worn and old. I first wiped it down with a damp cloth to clean it then thought to try reconditioning it with leather conditioner we'd purchased for our couch (I'm sure Amourall would work just as well). Voila, the old, dry roller was picking up paper again. Just open the rear door and that grey roller (it's black again when you recondition it) is at the bottom. Hope that helps.
May 11, 2010 | Lexmark C510 Laser Printer
Getting the message "241 Paperjam Check Tray 1" I've checked tray 1 and have not found a paper jam
Turn the printer upside down and shake to find any paper jam as in most cases you will find some paper or dust falling out and then try.
Jan 26, 2010 | Lexmark T630 Laser Printer
241 paper jam
Check the paper tray guides, check the the paper feed roller (remove the tray and look up in the printer) it is possibly worn and needs replacing, you can try to clean it (hand soap is as good as anything)
Apr 15, 2009 | Lexmark C510 Laser Printer
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
240 error
24x errors are paper jam error 241 tray 1 242 tray 2 ect. this means that the paper does not make it to the timming sensor inside the printer. this si usually caused by dirty pick wheels on the autocompensator located inside the drawer on the bottom of the printer
Oct 08, 2008 | Lexmark T522 Laser Printer
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Lexmark c510 241 paper jam error
I agree - the guides inside the paper feed tray must be EXACTLY aligned with the paper size. This fixed my problem.
Feb 06, 2008 | Lexmark C510 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
436 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
