Question about ACCO Brands Kensington Wall Notebook Power Adapter with USB Power Port
I have an acer laptop, that we bought a kensington charger for.... last night it started beeping when plugged in and will no longer charge! I am wondering if it is bad or what we bought two of them at the same time and the one for my husbands is not bad at all (his gets more use and is even on longer than mine). They are fairly new about 6 months (I would say). Any suggestions? really don't want to shell out another $100.00 for one. thanks
Try your suspect charger in your hubby's laptop an see if there's any problem. I suspect not. It sounds like your laptop has a hardware issue.
Posted on Feb 14, 2011
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
My cauzin Got Acer Aspire 5920 !! its charger stop working she buy another charger for it !! but due to inexperience she bought 24 volts instead of 18 volts !! after charging some time the laptop isn't...
Putting too much voltage into your laptop will cause a strain on the power regulating components and cause them eventually to fail and then you will have a dead motherboard.
Feb 22, 2011 | Acer Computers & Internet
The ac adapter for my Acer laptop has a continual beep in it and is no longer charging the battery.
Remove the laptop battery / plug in to mains, if beeping has stopped, faulty battery. If not then charger or mains faulty.
Feb 08, 2010 | Acer Aspire 6920 Notebook PC
My laptop was fine last night. i always use it on the charger but needed to take it off and use it. i did so and it ran out of battery so i put it on the charger but then it shut down. i just thought ill...
Remove the battery and mains adaptor. Press and hold the power button for a few seconds. Replace the battery and plug in the mains supply, press power for a few seconds and it should start up.
Aug 31, 2017 | Acer Gateway NV5814u Notebook
I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
Nov 05, 2009 | Acer Aspire 7720 Notebook PC
Acer charger plug no longer charges
It sounds like the connector on the motherboard has come loose. Don't continue messing with it as you will make it worse. You might be able to have a technician resolder the motherboard connector. It is a common problem with a variety of laptops and a lot of times can be fixed for a modest fee.
Sep 15, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Laptop Charger will only work is laptop is turned off.
it sounds like the charger does not have sufficient wattage for your machine. i would try getting a certified acer power supply.
Aug 14, 2009 | Umax ActionBook 333T Notebook
My charger is not working since morning. it was well and good last night.
What do u mean it's not working...??
Check for any loose connections...
It's a laptop charger, and u said it was workin' fine last night, then there's bound to be a loose connection......
If nothing else [like thunderstorms, voltage fluctuations, or any other harmful incidents] hasn't occured, it's connection prob....
Try using different plug-points.... Try checking the adapter if it's correctly connected or not...... If none of this works, call a comp spec.....!!
Jul 08, 2009 | Computers & Internet
ACCO Brands Kensington Wall Notebook Power Adapter with USB Power Port Logo
228 people viewed this question
Top ACCO Brands Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an ACCO Brands Computer and Internet Expert? Answer questions, earn points and help others
