Question about Amana NAV8800E Top Load Washer
Smoking washer Amana NAV8800AWW
Actually the washer was full of water, and had been agitating for about 1 minute when it stopped and started smoking..... it wouldn't do anything for about 15 minutes, and then I was able to run the spin & rinse cycle.
  • abcds May 29, 2008
    I checked it out, and you were right. The belt is ok, and it is working fine. Thanks for the help.
  • Anonymous Nov 14, 2008
    washer had started washing then it started smoking
  • 525 Answers
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
Posted on May 27, 2008
  • David Emmel
    David Emmel May 29, 2008
    All Right! That made my day!!
    Thank you for your generous vote, I greatly appreciate it!
    If you need any more assistance with anything, just ask for me, I'll be more then glad to help.
    Dave E, (Illeagle)
Started a quick was cycle to test washer without cloths. It agitates for about 10 seconds, stops for 5 seconds and agitates for 10 seconds again. The light array is suggesting it is going from wash.
new washers usualy start a brief agitate then locks the door and then starts watering again. depending on washer model it can do this a couple times to evenly soak the clothes at the start of a wash cycle. it is advised to not run full cycle in the washing machine with no clothes for it can damage the unit.
Jul 07, 2016 | Whirlpool Compact Stackable Front-Load...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Nov 22, 2008 | Amana NAV2335A Top Load Washer
Ammana washer wont agitate
If the motor is on in the agitation part of cycle and its not agitating your transmission spline is either stripped our your trans. is broken.If the motor is not on and its full of water in the agitation cycle make sure it is not syphoning.Please rate this !
Jun 22, 2008 | Amana NAV5800A Top Load Washer
Smoke
Your complaint is a bit vague but since it had only been in the cycle for 1 min., it should have been too soon to have enough water to start washing, so it's possible that the fill valve may have shorted out. Unplug the washer and inspect the area where your hot and cold fill hoses connect to the washer. Turn the water off and remove the hoses. If you can gain access to the part that the hoses were connected to, you should be able to visualize where the burning came from. It is possible a small water leak may have dripped onto the coils of the valve and caused it to short out, so that will need to be fixed also.
Hopefully, This is what your problem is.
May 27, 2008 | Amana NAV8800E Top Load Washer
Amana NAV8800E Top Load Washer Logo
594 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
