Question about Zanussi TC7114W Electric Dryer
I have a Zanussi condenser dryer TC 7114 w. It stops half way through the cycle indicating the water tank is full, but it is vertually empty and the water is collected in back of dryer and then leaks all over the floor. please help
I have just fixed this as below - your leak may be easier to see if you turn the machine on its front - there is a rear valve with a rubber bung and underneath a rubber pipe with a metal clip - check both for leaks - http://www.fixya.com/support/t4079509-full_water_indicator_lit_continuously
Posted on Oct 27, 2010
Zanussi ZDC8202P-WH. Only 10 days old. It stops halfway through the cycle with the 'water tank full' indicator coming on, but tank doesn't need emptying. It is in properly.
Return it back to the place of purchase and buy a different brand of dryer. Try Whirlpool or Sears Kenmore. You should have much better luck with these name brands.
Dec 01, 2015 | Zanussi Dryers
Zanussi TC7114W Tumble Dryer manual
Just click here for the direct download from PDF : TUMBLE DRYER TC 7114 W TC 7114 S
No websites or forwarding, that is just the manual from factory support website.
Vote the solution if this is what you are looking for
Sep 22, 2008 | Zanussi TC7114W Electric Dryer
The full tank light remains on even though the tank is empty. Is there a sensor which stops the dryer from restarting
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
The tank capacity is about 3.5 lt., enough for a drying cycle.
- Remove the screw (1) which secures the support micro and use a screwdriver for the two hooks which secure it to the sump.
- Lift them simultaneously and unthread the micro support towards outside
Putting upside down the support you can access the floating microswitch.
25069013-hcssld2gpo2sm22yg24xoxcy-3-9.jpg Inside the sump there is the float.
To extract it rotate the float 90° clockwise as shown.
Lift it up, rotate it towards outside and extract it.
While reassembling the pump, the float and the tank microswitch, repeat the same operations backwards, paying attention that when the micro support is remounted it is necessary to use a screwdriver in the fissure (indicated by the arrow), to lift the micro lever and lean it over the float (if this operation is not carried out the lever of the micro comes up alongside the float (it deforms) and the two components do not function anymore.
25069013-hcssld2gpo2sm22yg24xoxcy-3-20.jpg Dado
Sep 06, 2014 | Zanussi Dryers
Zanussi condenser dryers
It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
Below is explained how the condensate drainage system works and that will facilitate fault detection.
Dado
Aug 10, 2014 | Zanussi Dryers
Zanussi dryer tc
Did you locate the "tensioner" wheel that may have jumped out of the mounting hole...??
There are two wheels, one on the motor and one on the tensioner...
Apr 13, 2014 | Zanussi TC7114W Electric Dryer
I have a Zanussi Electrolux TC7103W condenser drier and for some reason the empty water light keeps coming on even though the reservoir is usually only half full. I have tried emptying it and tried un
Make sure lint build up is clear behind condenser
Sep 29, 2012 | Dryers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Zanussi TC7114W Electric Dryer Logo
568 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
