Question about Garden
I have a new Poulan Electric Chain Saw 1630.(green in color) Question.......should you be able to pull the chain easily around by hand after the chain is properly tensioned?
  • 2,926 Answers
There should be some drag while pulling. Proper tension is usually gauged by pulling down on the chain from the bottom of the bar. There should be approx. 1/8 of slack. If the chain is really hard to rotate regardless of tension, then the bar will need to be replaced also.
Posted on Oct 04, 2010
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
What is ball and chain oil
bar and chain oil.... it's the oil used for the bar/chain assy on chainsaws... used anywhere else it might cause a major catastrophy
Aug 28, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
Adjusting an electric chainsaw bar and chain
UN PLUG FIRST THEN Loosen the bar and lift with the chain then tighten with a screwdriver the screw is normally found at the front beside the bar re tighten the bar the chain should not be over tight check chain oil
Jul 17, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
What oil do we put into the poulan 3.0 peak hp
I assume you are referring to the Bar/Chain oil?
That would be Almost any Available brand chainsaw Bar and Chain oil, If that is not available you can use New uncontaminated SAE 30 motor oil.
May 15, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
I borrowed a friend's POULAN 14" ELECTRIC
Remove the side cover nuts and the cover, wind the bar adjuster screw fully back, it may be in the cover, or on the front of the saw, push the guide bar fully back toward the sprocket, loop the chain ocer the sprocket and lay it around the the guide bar, make sure the cutters on the top of the bar rail are facing away from the saw, this will make sure it is the correct way round make sure the bar adjuster pawl is engaged into the hole in the bar, if the adjuster pawl is in the cover, replace the cover making sure the pawl engages into the hole in the bar, refit the cover nur finger tight, adjust the adjuster screw so as the chain fits snug fully around the bar, loft the nose of the bar and fully tighten the cover nut, with a gloved hand pull the chain manualy around the bar to make sure it is fitting in the rails and the sprocket correctly.
Aug 31, 2011 | Poulan 14" Chainsaw
Cannot get chain back on bar of poulan pro electric chainsaw model 1630
Slide the bar on the studs all the way to the left, or rear of the chainsaw, and feed the chain around the motor sprocket, THEN along the top of the bar to the right, and around the bar's sprocket at the right end of the bar, if this doesn't work, report back. This is the original bar and chain correct?
Nov 21, 2010 | Poulan 1630 16" Chain Saw
Maintenance after use
Check the chain oil rate by running the saw tip at high speed near some cardboard for a few moments. A thin line oil should appear on the cardboard. If ok, then set the chain tension so that the chain doesn't droop from the under side of the bar, yet not so tight that it is hard to pull the chain by hand. Oil the sprocket tip bearing if the bar has one. If the machine sees a lot of use, it will help to remove the bar and chain, then clean the rear oil passages in the bar, especially the small holes that run from the large oil holes out to the chain groove. Turn the bar over at intervals to even the wear on the bottom edge. Keep the teeth sharp for less effort when cutting. Clean or replace the air filter regularly. Remove the spark plug on occasion to check the condition of electrodes and insulator (which should be a light to medium tan color). Electrode gap should be 0.020" Hope this helps!
Apr 17, 2010 | Poulan 1630 16" Chain Saw
I took the side cover off the saw and a piece that looked like a roll pin fell out and i don't know where it goes
There are no roll pins listed. The only pin listed is part of the bar adjustment mechanism. Are you certain it is not a small piece of branch? Are you certain it is a model 1630?
http://www.ordertree.com/modelinfo/PWE/1630-Electric-Saw/75.1630-Electric-Saw.1.59.1.html
Poulan.com (All Poulan Models)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 08, 2010 | Poulan 1630 16" Chain Saw
Leaks bar oil
The chainsaw squirts oil into the oil hole in the bar. The chain picks up the oil and carries it all the way around the bar lubing it and the chain. When you quit running the saw there is still a lot of oil on the chain and all away around the chain guide in the bar. Once you quit running it and it sets a while all the oil will follow gravity and run to the bottom of the bar and drip out into the case. It's just another one of life's little nuisances. Have a nice day! Obwhon
Oct 01, 2009 | Poulan 1630 16" Chain Saw
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
