Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
52 in RCA
Hi
My son was playing Xbox 360 on the 52 inch and it abruptly turned off and would not turn on again. Tried everything to no avail.
last week he was playing xbox 360 on the Toshiba 27 in and it blew, and won't turn on again. Is it the xbox 360?
  • Cuban Misu May 27, 2008
    If the flyback is replaced, will this be a lingering problem from then on?
  • RCA Master
  • 8,617 Answers
The RCA needs a flyback if its an ITC222 chassis which is waht the D52W20 RCA is. You can get a replacement flyback at the following link with free tech support so you can do the repair yourself which is a very easy repair. You need flyback number 259296. As far as the XBOX you should never play any video games on a rear projection TV as it can cause burn in on the CRTs if it is paused. video games are best played on a direct view, plasma or LCD TV. Rear projections like the RCa is not a good idea because of the possible burn in. heres a link to your flyback 259296
http://servicemanuals.vstore.ca/
Posted on May 27, 2008
  • Sonny Berry
    Sonny Berry May 27, 2008
    The replacement flybacks are usually better quality than the origionals so they tend to last longer.
When i turn my xbox 360 on it will play the sounds but no video
If your using the hi-def cable(red blue green) check that its switched to either standard of hi-def. Also if your using the hi-def cable it wont work if u have the white head in the same time as red blue green! Hope it works for you!
Mar 14, 2010 | Microsoft Xbox 360 Console
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Xbox 360 wont work on my Tv now - always been fine before
Hi...
Make sure the switch on the 360 A/V cable is in the right position. Also unplug everything from the unit and plug it all back in again.
From the reading I've done on tech issues the 360 has a lot of temporary issues like that.
Jan 02, 2009 | Microsoft Xbox 360 Console
Tv wont turn on
try replacing the flyback 259296 and CP150 both items are available at the following link with free instructions.
Dec 20, 2008 | RCA D52W19 52" Rear Projection Television
Hi when I turn my xbox 360 on the power button just flashed red.
Need more info on what happens. On my sons we would turn it on and the light let but that was it. We found out that the power supply that came with it went out. Try a new power cord from the plug on wall to the game system.
Dec 15, 2008 | Microsoft Xbox 360 Console
Hello my name is steve
Maybe Your A/V cord went bad maybe you should try buying a new one
Dec 13, 2008 | Microsoft Xbox 360 Console
Xbox 360
Make sure all the tv picture and audio cables are plugged in fully, if not fully plugged in, the cables can not work at all. If that doesn't work, consider sending it to microsoft or get new cables.
Dec 26, 2007 | Microsoft Xbox 360 Console
360 not starting....
ok you could try this
what you need is two towels just normal bathroom towels take everything out of your xbox e.g harddrive,controlers etc only things to leave in is the av cable and power supply as you wanna turn on the xbox lie a towel flat on the ground and lie the xbox on its side ontop of the towel turn the xbox on, you will see the error message and the red lights flash. wrap the towel around your xbox covering the air vents and then the 2nd towel put over the top. leave it on in the towels for about 20 mins then after that take all the towels off turn off the console and leave to cool down for 15 mins. turn the xbox on and it should restart again fine but only lasts for a couple of days then you have to do it again. wont fix it but will let u play while microsoft gets it.
its only a temperory fix you may need to contact microsoft
hope this help please rate me
regards grant
Nov 27, 2007 | Microsoft Xbox 360 Console
Sound But No Picture
This Just happened to me. There seems to be a lot of solder issues with the 360. I bit the bullet and tried the towel trick, where you over heat the 360 for about 20 min. I Let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again.
Jul 31, 2007 | Microsoft Xbox 360 Console
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
