Question about Electrolux Vacuums
I sucked up a sock I think its in the hose but I am not sure can you help me slove the problem?
  • 1,040 Answers
Try using a broom handle and push it out the the same end that it came in. If that doesn't work, straighten a metal coat hanger and make a small hook on the end of it. Reach in and grab it.
Good Luck!
Jim
Posted on Oct 04, 2010
Testimonial: "thank you, Jim I tryed the curiten rod still to short so I took a hard stiff wire and put a 3 prong fishing hook and it worked great thanks again. "
  • 1 more comment
  • lucyneglia Oct 04, 2010
    yes I have tried it but the coat hanger was to short i need something long enough . but what about if I use a snake like the plumbers use?
  • Jim Parker
    Jim Parker Oct 04, 2010
    You can try but you will need someone else to help you more than likely. I think the snake will be too flimsy. Broom handle or a stiff curtain rod.
    Jim
  • Jim Parker
    Lol...that cracks me up! Not everyone has fish hooks lay'n around. Good Job!
    Thanks for the rating Lucy!
I sucked up a sock and think it's in the hose
Remove the hose from the vacuum cleaner and push a broom handle all the way through the hose. If its in there, that will remove it.
Dec 15, 2013 | Dirt Devil Vision Wide Glide F16...
I think that I accidentally sucked up a child's
if you have a shop vac you can try blowing it out. for some reason this works better. You also might try a coat hanger with a U bend at the end.
Aug 09, 2011 | Electrolux EL6988E Bagged Canister Vacuum
I have a sock caught in the vacuum cleaner hose it is about 5 ft past the beginning of the hose and very stuck I have tried sucking it to the canister but no luck please help the suction is almost too good...
take a coat hanger and straightn it the best you can then make a small hook on one end of it and if you can unhook one end of the hose straightn the hose and try to go fishing with the coat hanger.
Mar 20, 2011 | Vacuums
I sucked in a sock or something. How do I get at it?
remove the lower floor unit plate,, and use a wire coat hanger to fish out the ' sock '. if it is way up the hose - then you might need to remove the hose from the unit and try and work out the blockage using your wire or a stiff dowel.
c...
Feb 16, 2011 | Kenmore Progressive Upright Vacuum with...
Any tricks to putting on a central vacuum hose sock? The last one took me 4 hours and I'm sure there must be an easier solution. It has no zipper.
Send it back and get one with a zipper. :) Okay did it come in a tube or with a tube? They are really necessary when putting a hose sock on. You first want to put the hose sock on the tube. You then slide the tube over the hose and take the hose sock off at the end. Tie the hose sock securely in place and start pulling the tube over the hose. The sock will slide off the tube and onto the hose as you go.
Jun 08, 2009 | Electrolux Central Vacuum
Clogged hose
if you have a drain auger then you can stick it in until it won' go any further then you have hit the sock.turn the cable and grab the sock and pull it to the surface.please leave feedback
Mar 30, 2009 | Electrolux Central Vacuum
Clogged hose and can not get the handle off
The best way to fix this problem is to Stick the other end of the handle into the wall inlet making the nozzle contact the pin jacks of the wall inlet. You may need to work the clog back and forth by then plugging the hose in normally. Eventually you will be able to work the clog out of the hose.
If all else fails you should use a plumbers snake.
Jan 06, 2009 | Electrolux Central Vacuum
I sucked up a sock in my powermate, and can't get it opened to see what the problem is. It won't work.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=820548
Generic problem for all Vacuums
I sucked up a sock
Posted by DFundis on July 22, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best thing to do is to see if you can open the power mate or powerhead, the sock is jammed in there and blocking the path of the dust and dirt. There should be some screws on the bottom to release the bottom plate or the top cover will come off, it would be one or the other It probably is stick in the gooseneck the swivel neck portion of the vacuum and or the wands or hose. If you need further help look in the owner’s manual or contact your local vacuum cleaner dealer in your area or call Sears cust serv listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 22, 2008 | Vacuums
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Vacuums Logo
85 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
