Question about RTO Motor Scooter 50cc
I have a 20023 Gelley 50cc scooter that doesn't seem to be getting any gas. Starts briefly if I spray starter fluid down airbox tube. Any suggestions?
Check fuel filter
Posted on Apr 01, 2011
1998 Audi A4 starter spray
no
you fix the reason why the injectors are not working
could be fuel pump , pressure regulator , injectors , wiring or ECM
have the fault codes read
Dec 28, 2017 | Audi Cars & Trucks
My 50cc scooter won't go over 30mph
Hi, Bob and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help Ruck won go above 30mph Thanks
Advice please 49cc won go over 20 mph
gy6 50cc to 100cc bbk upgrade still wont go over 30mph It Is The Ride
My scooter won reach top speed anymore scooters
SCOOTER WONT GO OVER 20MPH HELP
Mar 28, 2017 | GAS Motorcycles
Were do i spray starter fluid to get my 1994 buick roadmaster started Lt1 motor
Into the throttle plate , Look at round black rubber tube from air filter box over to the engine ! Use a screw driver , loosen the clamp and pull the hose off the engine , where it fastens is call throttle body . Look inside you'll see a round disk or plate what ever you want to call it . Have someone step on the gas pedal and hold it down , you will see the plate open . This is where you spary the starter fluid ! After spraying some fluid in have the person holding the gas pedal down , release it . Then try to start the vehicle .
Dec 10, 2016 | 1994 Buick Roadmaster
Gy6 scooter
Spray starter fluid into the carb with air filter off.
Jun 09, 2014 | Kymco Agility 50 Motorcycles
Keeway matrix 50cc scooter cuts starts to cut out after it gets warmed up
CHECK VOLTAGE WITH VOLT METER AND GAS/OIL MIX COULD BE RUNNING ROUGH
Apr 10, 2013 | 2006 Keeway Matrix 50
Hi there, i have a problem with my wangye 50cc 2 storke scooter. i bought it as it was a non starter, since then i have bought a new battery spark plug but i cant seem to get the problem, i have checked...
Kyle, there are a bunch of possibilities as to why it will not start. Do you have spark? If so, spray some starter fluid on the air filter or directly into the carb with an open throttle. Now try to start it. If it starts on the spray then the problem is probably in the carb. Bear in mind that the crankshaft seals may be bad. This would lessen or completely kill the needed pressure in the crank chamber. I am assuming the scooter is a two stroke. If it is a four stroke then the valves may need to be reseated. In any event, the carb should be disassembled and cleaned. The timing could be off. The rings could be sticking or shot. The exhaust port could be carboned up to a point the engine can't breathe.
May 18, 2010 | 2007 Wakan Road
Peugeot Vivacity 50cc Kickstart broken, but engine fine
the kick stater machanism has a spring on it
which may be brocken
Cheers Rob
Sep 17, 2009 | 2001 Honda Cityfly
Out of gas
u need to make sure the car has gas now and spray starter fluid in the oening in the throttle body.you may have to take the breather tube loose to spray the starter fluid and you may have to do it several times to get gas going back to he injectors again
Jan 04, 2009 | 2003 Nissan Altima
50cc Sunl gas scooter
You may need to adjust the fuel/air ratio. There is a small screw under the pull starter facing horizontally (its behind the plastic air filter cover, but accessable) adjust either clockwise or counter clockwise in small increments and give it gas and see if it dies or boggs down. Also check that spark plug is clean and not fouled, and air filter is clean and olied.
Jul 06, 2008 | Transport Schwinn Rechargeable Portable ...
RTO Motor Scooter 50cc Logo
374 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
