Question about Burlington Bassinet 252 Crib
I bought a burlington bassinet 253 W and it is missing some parts of the hood assembly, the pink ribbon and one pink insert for the basket and the tray at the bottom. Where can I find replacement parts? Thank you
10330 instructions
How do I assemble the Hauck D 'N'P Disney Winnie the Pooh Travel Cot as I'm having real trouble or is there instructions I can downliad
Oct 30, 2013 | Eddie Bauer Musical Rocking Bassinet...
Dont know how to remove the bedding from the bassinet to wash
Which part of the bedding is soiled and needs to be washed?
There should be a flat sheet that covers the mattress pad, an optional top sheet, a comforter, a dust ruffle, pillow sham and a decorative cover for the hooded area.
Remove the comforter & top sheet & set them aside. Pick up the mattress inside the bassinet, remove the flat sheet on it and put that with the other items to wash. Leave the mattress pad out, and you should be able to see the dust ruffle. The dust ruffle goes under the mattress pad and hangs like a skirt on the bottom of the bassinet. Pick up the dust ruffle and untie any ribbons that might be used to anchor it on the sides or bottom area. Depending on the bedding set you bought or are using with the bassinett, the piece that goes around the hood area might have elastic to keep it snug, or if you are using the default that came the model that is sold in California, US - its not really removeable without a lot of trouble and other problems - (I would suggest leaving it on unless its REALLY soiled).
Jun 07, 2011 | Eddie Bauer Musical Rocking Bassinet...
Where can i buy the crib to toddler bed conversion kit for model # 4341-1 ??? originally bought from burlington coat factory i believe.
Call Delta's Parentlink customer service number.
Hours of Operation Monday through Friday
8 a.m. to 8 p.m. (Eastern Standard Time)
1-800-377-3777 extension 6221, or
212-645-9033
Feb 24, 2011 | Delta Luv Lauren 4341
I am looking for parts for a cosco 10T44 white metal bassinet.
Did you ever find the parts to cosco 10T44 white steel bassinet. We have a similar problem. After assembling it, missing caps that are attached to the middle bars and the side bars. The long thin pole extends further out out on one side because of the missing caps and is there a pin to keep the cradle in place? I do hope we can replace those parts. My younger daughter is expecting her first child and would like to use the bassinet that was handed down from her sisters. It's been 13 yrs. stored away in the attic. Hopefully you can help make suggestions..... Thank you
Sep 09, 2010 | Cosco Baby Gear
I need parts for a chatham lifestyles crib ?
hello I have contacted LaJobi customer service and they are going to help in finding parts for that crib :)
May 21, 2009 | Baby Gear
Replacement parts for koolcraft bassinet
We have a Koolcraft Ultra Lite Vibes Model #18274-YT. We stored it at a friend's house and when we got it back there are missing parts, the four legs. New baby is due any day now. What can we do to get these parts? Margie (margiekc21@yahoo.com) Please help.
Sep 24, 2008 | Kolcraft Ultra Light Vibes 18275 Crib
Replace parts
You can call 1-800-544-1108 to get replacements parts.
Jun 26, 2008 | Eddie Bauer Musical Rocking Bassinet...
Burlington Bassinet 252 Crib Logo
106 people viewed this question
Top Burlington Baby Gear Experts
Dorel UK
Dorel UK
Are you a Burlington Baby Gear Expert? Answer questions, earn points and help others
