Question about Foxconn (945G7MA-8KS2) Motherboard
Problem ide i have M.B foxconn 945ga7ma and i need to boot frome cd rom on ide but there problem it not off cd rom but the problem in M.B bios
    President:
  • 2,351 Answers
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 27, 2008
Cd Group Boot Priority not installed
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Mar 27, 2011 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
I have a dell dimension 3000 desktop. I removed a cd rom drive and replaced it with a audigy sound blaster front panel drive. when I boot my PC it says primary drive not found, press F1 to continue, Press...
Your computer is configured to recognize specific devices in your computer. If you removed the CDROM drive, you need to tell your computer that it's gone, and that you're aware of it. That message is kind of like a "Hey, there's something missing from your computer... did you know about this?"
You should boot your computer up and get into the BIOS. When your computer turns on, you'll see a message in the corner that says something like "Press F2 for BIOS" or something like that. Get into the BIOS menu using this option. When you get into the BIOS, you'll need to find the sub-menu called "IDE Devices" or something referring to IDE drives. You should see two IDE channels, with two possible devices per channel. You should see the entry where your CDROM drive used to be - change this option to "Disabled" and then save your settings and reboot the computer. The message should go away. Good luck!
Mar 08, 2010 | Dell Dimension 3000 PC Desktop
I want my desktop to boot from cd. But in the boot priorities there is no option for CD-ROM. How can I make CD-ROM first boot priority?
If there is no cd rom, you need to check for it your bios detects your cd rom drive, and make sure you connect it properly.
If you are using IDE CD-ROM,make sure it doesnt conflict on your Master-Slave configuration. if you are using SATA CD-ROM make sure it connects properly to your SATA Ports, and also check if you have properly connect the power cable to your CD Drive.
Jan 05, 2010 | Computers & Internet
Vt82c693a motherboard cant show ide hdd in award gui bios check
There may be a need to check the Jumper settings on the IDE drive, I would make sure the jumper is in the master setting and also to try to keep the cd rom connected also when you boot it up again.
Blessings,
A/V Media Guy
Nov 21, 2009 | Computers & Internet
I have a Dell Dimension 4600. I need to re-install Windows XP Professional. The PC won't boot from the CD-ROM. When I choose F12, then Boot from IDE CD-ROM, the PC boots directly to Windows. how can I get...
Check the BIOS to make sure that the CD rom is the first boot devices in the bootup sequence, also make sure that the cd rom does show up in the BIOS.
Make sure that the CD Rom itself is good or the boot cd you are using is good, try it on other PC.
Oct 29, 2009 | Dell Dimension 4600 PC Desktop
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Willn't boot up frome the cd rom
You can do this by changing the BOOT Priority in your BIOS settings.
To get into BIOS:-
When you first turn the system on, you get what they call a POST screen (normally has the laptop logo or enegy star monitor rating), at the bottom of the screen, it should give you an option or two (i.e. F1-Boot Options, F2-Setup (also called BIOS). Different systems use different keys to enter the BIOS (or SETUP), this is usually F2 or Delete.
Once you are in the BIOS, just have a browse for BOOT OPTIONS or BOOT PRIORITY, and change the value of FIRST BOOT to CD-ROM.
Save these new settings to CMOS and exit. The system will now reboot, and this should solve the problem
Nov 28, 2008 | Computers & Internet
Faulty Memory Stick
use live cds and boot frome it u will be abel 2 access
Feb 12, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Foxconn (945G7MA-8KS2) Motherboard Logo
495 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
