My washer is showing F20 across the screen and my manual does not show anything.
  • Washing Mach... Master
  • 8,220 Answers
What can I do to reset may washing machine showing an error word of f20
F20 is a water inlet problem not sufficient water supply. Select power/cancel twice to cancel cycle unplug washer or disconnect power
Check both hot and cold are open completely
All screens a
Jul 14, 2015 | Maytag Washing Machines
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
I am having trouble with my washer. It is showing the F28 error code and then when I get that fixed, it shows the F20 error code. Can you please tell me what to do to get it running again. Thanks
F20 I believe is low water flow. On the intake fitting on the back of the machine where the hot and cold hose hook up there is a fine screen inside the fitting on the machine. My cold water screen was clogged from stuff in old pipes. Cleaned it and no more e F20
Feb 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Showing code F 20
f20 code means no water is entering the machine. make sure your water hoses are connected properly and that the water is turned on. could also be a problem with your pressure switch.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Shows f20 and stop working
F20 No water detected entering machine. Tech sheet is in the bottom. Remove panel. Duet Service Manual34409e2.jpg
Aug 30, 2010 | Kenmore HE2 Plus Front Load Washer
Hi, What does a F20 error mean on a maytag 3000 series?
See this page: http://maytag.custhelp.com/app/answers/detail/a_id/2887/~/display-shows-f20-or-fh---front-load-washer
Your washer water valve inlet screens may be dirty / covered with debris and need cleaned. Some hoses have additional screens installed at the faucett connection depending on who did the install process. Low water pressure will also cause this code.
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Maytag Washing Machines
Maytag the washer quits and a f20 or f11 shows up
Its a water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Apr 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F20 Error code
be sure to ck fill hoses make sure both are turned on all the way ..remove hose at washer end ckd screen inside inlet for sand/rust/gunk pull screen out to clean and be sure to reinstall it or you're asking for trouble down the road..also ck faucet end just in case someone installed one there 2..by the way just having cold water only on will cause same problem
Aug 26, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
