My screen is green i was going to change monters didn't work so i put it back and it turn green.help please.
Red, Green, and Blue are the colors sent from your computer to the monitor. Sounds like red and blue are not working. If you've tried a new monitor, I'd try a new video cable next. Then clean the connector on the back of the computer (compressed air). Finally, replace either the video card or the computer.
Posted on Oct 04, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Why is the finepix games s2900 camera saying I should turn off the camera and put it back on again
I recently got this camera and it did the same thing to me. I found this site and did what quido777 said to do, smacked it on my leg, didn't work. But then I decided to check the memory card and took it out and put it back in, and now its working. I'm guessing it didn't detect the memory card for whatever reason. Before all of this I called tech support and they didn't know **** and wanted me to send it in. I'm glad I decided to fix it myself before going through all of that. But one thing is fore sure, after this camera, I'm never purchasing from Fujifilm again.
May 19, 2012 | Fuji FinePix Cameras
Briefly: laptop cant turn on Detail: After pushed power button, the note book didn't turn on. Screen kept black. Power button didn't light on(usually should). The laptop is without any sound...
The first solution I'd recommend is removing the battery and then trying to power on just with the AC adapter. Why are you afraid to remove the battery? no data will be lost.
It maybe that you have a dead motherboard or that there had been a power failure while you were putting your machine to hibernate.
Jul 03, 2011 | Computers & Internet
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
* Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control)
Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control)
* While holding the above buttons, plug in the TV.
* The TV will turn on with the "K" or "K123" appears om screen.
* Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My HTC HD 7 phone keeps turning off it goes to the white screen with green HTC then shuts off and keeps doing the same thing over and sometimes when i try to use it and i tap the screen then it shuts off...
I finally had to have them replace the unit. If doing a factory reset does not help, then I would have them replace it. Mine started rebooting infrequently, but then started doing it more often. They didn't waist any time getting my replacement out.
Please make sure you back up all your contacts/email before proceeding. I use Google on my phone through the Outlook option. Google/Outlook syncs all my mail, contacts, and calendar.
RESET: Software: SETTINGS > ABOUT > RESET YOUR PHONE
Hardware: 1) Turn off phone 2) While holding down both the Up/Down Volume buttons, turn unit on 3) Keep holding down the volume buttons until white screen appears 4) Press the Down Volume button to reset to factory defaults. 5) Restart phone
Jun 28, 2011 | HTC HD7 Cell Phone
When i turn my pc on, monitor boots up then goes to sleep and will not come back on
you can make your monitor didn't go sleep from screen saver window select advanced and change option to never
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Computers & Internet
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Unpluging 4 pin power on mobo Pc starts but no video,keyboard etc
how do i fix the monter I tryed to put the power and rest on and motherboared comes on not the monter
Mar 13, 2009 | ASUS P4SGX-MX Motherboard
Suddenly it doesn`t focus
try resetting your camera. In record mode press menu. go to setup tab go up to reset press right arrow highlight reset press set. If that doesn't work Call the repairs center at 800-706-2534 and then keep choosing option 1. Tell them what's going on and that you would like to send it in for repairs. If they ask just lie and tell them you already talked to tech support. LOL
Oct 10, 2006 | Casio Exilim EX-S600 Digital Camera
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
