Question about Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack
My father-in-laws gogo will be not used for several months while he's in florida. how should the battery be stored/charged while not in use?
  • 692 Answers
Charge the batteries fully and remove the battery pack from the scooter. About once a month charge the battery pack. It shouldn't take long to charge since you are not using the scooter Don't overcharge when the light on the charger turns green turn it off and unplug it from the battery pack. This should keep the batteries fully charged and fresh when FIL gets back home. Hope this helps you
Posted on Oct 04, 2010
Testimonial: "thanks for your help!"
Friend asked to store Aston Martin Vantage8 in my garage for a few months, and will need to plug in a trickle charger. What does the trickle charger do? and how much will it add to my electric bill?
Trickle chargers keep the battery fully charged.
They usually have a small cube-shaped transformer with a cord and plug or alligator clips.
If you look on the cube part label it will tell you the "wattage" , probably around 20 watts or similar.
This means while it's in use it draws 20 watts through your electric meter, the device that calculates your electric usage/bill.
You are charged for kilowatt hours.
To calculate how many kilowatt hours the trickle is using
multiply 20 X 24 hours X 31 days in a month .
Or 14,880 about 15 kilowatt hours a month.
In Florida a KWH is about 12 cents so it would cost you about $1.80 a month to trickle charge.
Dec 02, 2017 | Motorcycles
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
Where does yellow wire from PTO go?
Have you tried to get manuals for this tractor by googleing?
Nov 01, 2014 | John Deere Garden
I plug charger in and nothing happens no lights or anything
got the same problem the gel cells drain to a level that is too low for the charger. A suggested fix I have seen is to jumper a car battery across the gel cell to fool the charger so it will go into charge mode.
I have not tried this my self yet as I have to remove the chair to get to the batteries on my father in laws ride on chair. The nursing home took the chair off him and left it in a shed without it being on float charge for over 6 months and now I can't charge the chair up.
Oct 08, 2014 | Health & Beauty
How do I charge the Hoveround mpv 4? I plugged the charger into the chair and plugged the cord into the wall using an extension cord. The red light on the box turns red when in the "on" position but the...
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
Jun 22, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
The new batteries that we bought for our gogo elite do not stay charged for more than 15 min of use. The batteries are only 3 months old
battery cells damaged
replace
it
its in warranty even if its not og
other third party battery makers give 6 month warranty
Jun 03, 2010 | Pride Mobility Products Go-Go Elite...
My Father in Law passed away and I am trying to get his Craftsman 5hp wood chipper running so that my Mother in Law can sell it. It has electric start. I assume with electric start there must be a battery...
You can visit the Craftsman website to get this info. You will need your Model Number and Serial number to download an owners manual. The manual should show you where the battery is.
Apr 19, 2010 | Heavy Machinery
I have a Lowrance iway 500c. When I power it up, it does not find my current location. It comes up with a location in Florida where my father-in-law was in Florida with the unit earlier this year. . When I...
When was the last time you went into the your settings and update your software or configured the unit? On cloudy days you can't do this. On a bright sunny day go outside and try this.
Dec 14, 2009 | Lowrance Iway 500c GPS Receiver
My gogo-ultra will not run. it has been stored
hi,
Check the connections between the battery and motor, if the rear come apart check there connections there,
If the connection with the batteries string loaded, rough them up slighty with a wire brush but be gentle and is there freewheel lever right in position for drive.
Regards
GeWiz.
Oct 24, 2009 | Pride Mobility Products Go Go Ultra X 4...
How do you check if altenator is charging battery,
Most vehicles if you get the car running and unhook the positive battery cable it will stay running that is because it is running off the alternator. if it dies like your talking about I would most definitely say your alternator needs to be replaced. Most likely when you jumped your father in laws pick up there was a bad ground somewhere and your alternator got a surge of electricity and it fried it. Hope this helps.
Mar 09, 2009 | 2005 Ford F-150
Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack Logo
501 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
