Question about Mitsubishi WT-46809 46" Rear Projection Television
Turns On then immediately turns itself off
Need help with this problem. Today I turned my TV on and then
it cut itself off after about 2-3 seconds. Not even enough time for
a picture to show.
Has anyone had this problem?
  • 6 more comments
  • xraykid Jun 02, 2008
    Mine would turn on then off,now the green light turns on and stays on but still no picture.Trying to find an answer here,
  • Anonymous Jun 09, 2008
    I have the exact same problem! It is really starting to anger me, because I have tried everything to get it to work again, and it just doesn't seem to want to. Please help if you have any suggestions!!!
  • KJV1611 Jun 10, 2008
    My TV turns off after a few seconds, this has happened before and the problem was the circuit board. The repair man said that this was a flaw with thier boards getting so hot that they melt the solder on the boards causing them to short out. This is a reoccuring issue that I keep experiencing and I will never buy another Mitsubishi as a result.
  • KOVO Jun 18, 2008
    Wow, all these at once. Mine started this yesterday - same thing, turns on for two seconds and then it shuts off. Something must be over heating causing this to happen .
  • Anonymous Aug 08, 2008
    hitachi60fx32b turns off
  • Anonymous Aug 18, 2008
    This is really weird. I experienced this same problem over the weekend and just happened to find this message board, all with similar problems around the same period of time. I have a repair person coming out Wednesday to look and give an estimate. Anyone know what it costs to repair?
  • Dallas Area Aug 18, 2008
    This is weird. I experienced the same problem over the weekend, just happened to find this message board and all the similar posts from around the same date. Obviously an issue with this unit. Anyone know what the cost of repair is?
  • szar6 Nov 17, 2008
    My Mits 42" also just started doing the same thing. I have a tech coming out Friday. Will let you know how much to repair.
  • 927 Answers
Good Day y'all;
First I will tell you what the factory tells us then I will tell you what the problem may be: This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. This model is also known to get fluid on the boards. The fluids come the picture tubes, this helps projection TV's to keep cooler tubes, all companies use this method, but MIT has the biggest concern of the leakage.
Sorry, but hope this was helpful. These TV's can repaired, shields can be provided. Call an authorized service dealer to this repair.
Good Luck, big IRISH.
Posted on Jul 15, 2008
    New Friend:
The timer light flashes green but the tv wont stay on
Posted on Jan 17, 2013
Change the fuse F9A05 THATS WHAT I HEARD
good luck people
Posted on Aug 16, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly. > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from
Jan 13, 2016 | Samsung Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Tv turns on and turns off after 5 seconds
jim if know how to soldering iron ,resolder your tv especially the power supply
Jan 26, 2009 | Televison & Video
RCA TV quit working
is it back projected if so lamp needs changing if not power supply faulty
Dec 08, 2008 | RCA HD52W58 52" TV
TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Jun 22, 2008 | Televison & Video
The flyback transformer are damaged.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
Self turn on and off
please change i.f board if problem not solve thet means problem with lcd panel
Mar 01, 2008 | Hyundai ImageQuest L17T 17" LCD Monitor
Mitsubishi TV WS-55511 Turns Off after Turning On
My mitsubishi big screen tv turns off in few seconds what should I do and I just got tv today please someone help
Oct 28, 2007 | Televison & Video
My T.V is turning itself off after 2 seconds where you can hear sound but there is no picture
Hello according to the symtom that you have describe I think that maybe you have activated the sleep function button on your tv and if this is not so maybe there is an internal problem on the main board of the tv.
Jan 10, 2007 | Sylvania 6413TD 13" TV
Mitsubishi WT-46809 46" Rear Projection Television Logo
1,650 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
