Question about Denon D-C1 Shelf System
CD does not play
Hi, my D-C1 micro system has a fault i so far as it refuses to play cd's but if I go to CD1, then to CD6 then back to the CD i want to play, it will play it 80% of the time - this is really annoying and i was wondering what might be the cause of this fault.
Cheers
  • nicolapalmer Oct 06, 2008
    i try skipping a track on a cd but then it won't play any of it
  • 4,234 Answers
This sounds to me like the loading mechanism is having problems. It may be as simple as the grease gumming up a bit, or the motor having a dead spot. Without seeing the machine itself, it is hard for me to say. I'd rebuild the loading mechanism and regrease it. Figure on the local labor rate for this repair as no parts should be required unless the motor has failed.
Dan
Posted on May 28, 2008
DEAR SIR/MADAM WHEN I TRY TO RECORD MY VOICE VIA MICRO PHONE SINGING WHILE THE CD MUSIC TRACKS ARE PLAYING I COULD NOT RECORD THAT TO THE MINI DISC.PLEASE ADVISE ME HOW COULD I CONNECT IT DIGITALLY
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
Jan 16, 2016 | Tascam Audio Players & Recorders
Hi got bmw mini the multi changer in the boot when i want to play cd it come's up with no discs can you help
Same problem on mine..what I found was if you take out the magazine..re-insert and push in a bit harder..it displays "CD CHECK" on the dashboard and may just manage to play CD1 before it reverts back to "NO DISC"....I'll try changing the magazine as mine at least plays once in a while. It would only say this if the magazine is not able to supply the player with a disc.....Any use?
Dec 14, 2009 | Car Audio & Video
The cd player refuse to play,just a click sound i hear.
Hello, Clicking sounds from a CD6 player is indicative of the main worm drive in the CD mechanism failing. Unfortunately not a repair you can do at home as it does require disassembly of the unit.
If you would like more information on repairing your unit and the options you might have for getting it back up and running, please contact me at rcruz@radiomedics.com or 877-472-3466
Thank you,
Robert Cruz
877-4-RADIO-MD
Jan 22, 2009 | 2004 Infiniti FX35
"NO DISC" reading
Try this CD realignment process built into the Sharp XL HP505: Have unit off.
Hol down the square (stop) button and the X-BASS button while pressing the ON button. This starts the CD TEST. press play, the memory, then memory, memory, memory, adjustment lights will come on the screen. FOF, TOF, TBAL, TGAN, FGAN, RFLS. press cd1 - track 4, press cd2 - track 9, press cd3 - track 15. Press square (Stop).
If all the cd trays are full, then will light up . This worked for me.
Aug 02, 2008 | Sharp XL-HP505 CD Shelf System
Problem playing CD from USA
Seems to be a media problem. I would contact the seller and explain the problem to them ...accordianman
May 08, 2008 | Audio Players & Recorders
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
No sound while playing dvd/cd
sound muting circuitery prblem or sound swiching section problem can occure this type fault.sometimes it can be cd /dvd printed board problem.give it to qulifid technician .
nuwan.
Dec 12, 2007 | JVC FS-S77S DVD Micro Component Stereo...
Blaupunkt IDC-A09 5-Disc CD
THE IDC-A09 CAN BE REMOVED BY INSERTING THE STANDARD PHILIPS REMOVAL KEYS INTO THE TWO HOLES EACH SIDE OF THE UNIT AND FORCING THEM OUTWARDS SLIGHTLY AND THEN THE UNIT SHOULD SLIDE FORWARD
Dec 03, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
308 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
