Question about Compaq Presario sr1303wm Computer - AMD Sempron 3000 - 2.0 GHz - 256MB - 40GB - DVD/CDRW Combo ... (PP150AR) PC Desktop
Good Morning, Can I add memory to this computer? I read somewhere that you cannot add memory. I believe it was on Compaq's website, but I cannot not find the information anymore for some reason. My computer is refurbished, if that makes a difference. Thank you for your help, Melanie
    Guru:
  • 124 Answers
Yes you can still add memory on your computer. I believe that the memory installed in your computer is one 256MB ddr sdram. Since the motherboard of your computer has 2 memory slots, it can support up to maximum 2 GB memory ( unbuffered PC2700/2100 non-ECC DDR SDRAM memory ). Or 1GB on each slot. Hope this helps.
Posted on Oct 04, 2010
How to add or change DDR2 Memory Compaq Presario SR5110 desktop computer
Just remove the power cord, open the case, turn the computer on it's side and you will see the memory sitting in the slots. Push down on the latches on both ends of the memory slot and then you can pull the memory out.
Be sure to replace it with compatible memory or it will not boot up. Also it you install more than your system will hold, it will not register the excess.
Try 4 All Memory website. It will tell the type, how many slots you have and the maximum amount of memory it can hold.
http://www.4allmemory.com
It looks like your system uses DDR2-PC2-5300 Memory. It has 2 slots and a total capacity of 4GB which means each slot can hold a 2GB chip.
http://www.4allmemory.com/memory/compaq-hp-presario-sr5110nx/
Jun 03, 2012 | Computers & Internet
How much ram can i upgrade my compaq presario? I keep getting conflicting info. The tech at Office Depot said I was maxed out 2Gigs and upgrading any more would shut it down. But I'm reading forums...
One good and easy way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for each slot and the total capacity for that motherboard.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
I hope that was helpful to you, good luck.
Joe.
Nov 05, 2011 | HP Compaq Presario SR5350F Desktop PC...
I want to transfer music from my computer to my cell phone...other laptops have a sd memory card slot...where is the one for the compaq cq60-466dx
Your laptop may not have a sd memeory card slot, if it has it should be either the front or either side, if none there, you can link your mobile phone to your laptop using a compatable usb. Should have had one provided when brought your phone.
Mar 05, 2011 | Compaq Computers & Internet
Opening the Case
Go to Compaq website for support. They explain everything.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&dlc=en&cc=us&product=374513
Hank
Jun 26, 2009 | Compaq Presario 5000 PC Desktop
Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Jun 10, 2009 | Dell OptiPlex GX280 PC Desktop
Add Memory In Compaq Deskpro 6000 P2 Shuttle PC?
No, it is in the actual box which contains the power button. You'll need to open that box and take a peek inside. You will see something similar (not exactly the same) to what is depicted in this picture. Now, in your particular instance one or two of the slots will be occupied by memory-sticks.
That is where your memory will be inserted to add extra RAM. Now we need to find out what type of memory you have right now, because we will need to match it. Download this utility and install it onto your computer. Afterward open up the area for system-memory (Or RAM) and determine what type of memory you have. Is it DDR, DDR2, or some other type? Once again, we will want to try to match the speed, type, and possibly even the brand to ensure the RAM will work with your system.
Once you have that information head online to this website. Once it loads navigate to Computer Hardware>Memory. On the left select, "Desktop Memory." Afterward use the, "Guided Search" to narrow your search to the type that is in your system, that way you're looking at memory types that your system supports aiding you ever so greatly in your choice.
Now just to clarify. This will increase the system-memory not storage-space. With storage-space I mean a hard-drive which contains all your files, personal data, and the Operating System in your computer. If you want more storage-space we will need to buy you a new hard-drive. This won't be as difficult, we just need to know if you have ATA or SATA. Most likely you have ATA since your computer appears to be oldler, so I would recommend a Seagate ATA hard-drive from this website. Once the website loads navigate to Computer Hardware>Hard Drives. Afterward, on the left under, "Hard Drives" select, "Internal Hard Drives." Afterward on the left under, "Guided Search" select the, "Interface" type, "IDE Ultra ATA100." Afterward make a pick on a hard-drive that has the storage space you're after. (The only seagate doesn't have a lot of space, so the ultimate decision is up to you.)
So get back to us with your choice along with the information on your RAM and hard-drive types and we'll let you know if you made a good decision.
Feb 17, 2009 | Compaq DP 6000 LOGIC BOARD (322735001)...
No signal
this is most likely a problem with your graphics card. do you have an integrated or an add-on video card?
Jan 05, 2008 | HP Compaq Presario SR2150NX PC Desktop
Add more memory to my computer
Not able to access it in what way? Is there a password for the BIOS or something? Normally on most (all?) Compaq models, F10 is the key to use to access the BIOS.
Sep 22, 2007 | Computers & Internet
Compaq Presario sr1303wm Computer - AMD Sempron 3000 - 2.0 GHz - 256MB - 40GB - DVD/CDRW Combo ... (PP150AR) PC Desktop Logo
119 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
