Question about KitchenAid Pro Line Coffeemaker Coffee Maker
My kitchenaid proline coffee maker won't brew coffee.When I turn the button to start it beeps and doesn't turn on.
heatman101
  • 43501 Answers
SOURCE: The blue light on the left doesn't light up.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 03, 2011
SOURCE: coffee maker won't start and just beeps when plugged in
The door on the top is not closed properly. When you open the top door(cover),you will see a button that is located on the top of the grinder cover. that is a switch that tells the coffee maker that the door is closed and can safely make coffee..please check that all parts are in place and top door(cover) is closed comepletly. good luck.
Posted on Jun 26, 2007
SOURCE: Kenmore Coffeemaker 100.82006
hi gayley i could have wrote your post. i am so mad . i brought this coffee pot in oct. or nov and really liked it . it brews really fast . now i cant find the receit. hope some one knows what to do
Posted on Feb 16, 2008
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
  • 145 Answers
SOURCE: How do I turn the beeping off on my Kitchenaid
There is no programming function that allows the beeping to be turned off on a Kitchenaid Coffee Maker.
Posted on Jul 08, 2009
Beeping sound, won't brew
Our Hassle-Free Replacement Warranty guarantees that if your PRO LINE™ countertop appliance fails in
the first two years, KitchenAid will replace it free of charge. We will:
  • Deliver a replacement to your door
  • Arrange the return of the failed appliance
  • Guarantee the new appliance for two years
    For more information or complete warranty details on KitchenAid® PRO LINE™ countertop
    appliances, please call Customer Service at 1-800-541-6390 or click here.
    spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif Product Literature spacer.gif Additional Resources
    Feb 15, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
    How do I run the clean cycle?
    I assume you mean descaling the coffee maker when the Clean indicator flashes after a brewing cycle. You can use a packaged descaling product or white vinegar. For the packaged descaling agent, follow the package directions for the ratio of product and water. If you are using vinegar, fill the carafe with a 50:50 mixture of water and vinegar.
    Remove the water filter and remove any coffee and coffee filter from the brew basket. Make sure the unit is plugged in and turned on. Pour the descaling mix from the carafe into the water tank and then place the carafe in the coffee maker. You have 10 seconds to program the cleaning mode or the unit will return to the standby mode. The next step depends on the type of carafe. For a machine with the glass carafe, press Mode 6 times. Otherwise for a unit with the thermal carafe, press Mode 5 times. The Clean indicator will blink. Press Program/Set followed by the + or - button to select Clean On. Press and hold Program/Set until you hear the beep. Press Brew and wait for the cycle to complete (the Clean indicator will go off). Then do two brewing cycles with water but no coffee or coffee filter. Discard the fluid from the coffee maker from all three cycles. Wash the brew basket and then reinstall the water filter.
    If you notice an odd taste to the coffee when you next brew some, do at least one more rinse with water (remove the water filter and coffee grounds/filter).
    KitchenAid manuals are available from their site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The direct link to the manual for the Kitchenaid KCM223OB is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10321647.pdf . See page 13 for the directions.
    I hope this helps.
    Jul 04, 2011 | KitchenAid KCM223OB
    Kitchenaid Proline program light doesn't stay on & it won't auto start brewing
    Pro Line appliances have an extended 2-Year hassle free warranty on them. If you are experiencing any problems with a Pro Line coffee maker, I would suggest calling Kitchenaid Customer Service.Their toll-free telephone number is:
    1.800.541.6390.
    Aug 03, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
    Need To Turn Off Beeping After Coffee Brews
    on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
    May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
    How do I turn the beeping off on my Kitchenaid Coffee Maker when it's brewing?
    Apr 01, 2009 | KitchenAid KCM511OB 10-Cup Coffee Maker
    KitchenAid 10 cup coffee maker Model # KCM511ER-1 Ser# WGT4409334 Pushed the Brew button after a Min. or two it beeped and Replaced the time with "Err2". the coffe maker did not warm up or...
    An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
    If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
    Their toll-free telephone number is 1-800-541-6390.
    Aug 16, 2008 | Black & Decker Spacemaker 10-Cup Coffee...
    Coffee maker beeping
    Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
    Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
    Turning off the beeper
    The manual is not too clear on this function. Turn the coffee side on, press the middle button on the coffee side for > 2 seconds and then use S1 and S2 button to select a mode that does not show the bell.
    Jul 11, 2007 | Krups XP2070 10 cup Coffee Maker/15 bar...
    KitchenAid Pro Line Coffeemaker Coffee Maker Logo
    1,533 people viewed this question
    Top KitchenAid Coffee Makers & Espresso Machines Experts
    Ismael Rodriguez...
    Sal De
    Craig Butler
    Craig Butler
    Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
