Question about Minn Kota 55 EdgeHand Bow Mount Motors
Directional arrow on top not working on my minn kota trolling motor
SOURCE: The Minn Kota trolling motor
Mine did the same thing and i think that it could be the relay under the switch cause i had power when i directly touched both neg. and pos. so i would diffently take a look at that.
Posted on Oct 02, 2008
  • 10 Answers
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
Editor925
  • 285 Answers
SOURCE: where to buy replacement brushes for electric
http://www.northlandmarine.com/MinnBushKit3.25.htm
Posted on Jun 20, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
  • 91 Answers
SOURCE: lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
Posted on May 31, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Motor works fine but red indicator arrow does not move in direction of motor . what could be wrong.
    you could have a broken gear inside the top of the motor. take the cover apart and you will see 3 plastic gears. one on the motor shaft, one on the indicator and one in between. check all gears are ok.
    Jul 01, 2010 | Minn Kota Edge 40 Freshwater Bow Mount...
    Lookinf for a manual for a minn kota model 55d
    May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota 55 directional problem? (night fisher)
    Hi!
    Here is a schematic:
    Max 55
    There is no LIGHTED directional indicator, but there should be an indicator nonetheless on top.
    Best of luck!
    Mike
    Jul 07, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
    You need your serial number of the trolling motor, length of shaft, and thrust poundage.
    or you could call Minn Kota direct and give them the same information at 800-227-6433.
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota 55 EdgeHand Bow Mount Motors Logo
    172 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
