Question about Apple iPhone Smartphone
When can we use blue tooth in I phone like other mobiles???m
Initializing blue tooth watch mobile
Your mobile have some problem.
Feb 21, 2014 | Cell Phones
I try to connect my blue-tooth headset model NOKIA BH-209 with my Nokia E63 mobile phone , but My NOKIA E63 mobile phone does not search NOKIA-BH-209, my NOKIA blue-tooh BH-209 is working with an other...
PLEASE MAKE SURE THAT YOUR PHONE BLUE TOOTH IS WORKING PROPERLY IF YES TRY CONNECTING YOUR PHONE WITH OTHER BLUE TOOTH HEADSETS. IF IT GETS CONNECTED YOUR PHONE DOESN'T SUPPORT YOUR HEADSET. IF IT DOESNT YOUR PHONE ISN;T WORKING GOOD.
Jul 18, 2011 | Cell Phones
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
I AM TRYING TO PAIR MY MOTOROLA HEADSET HS801 WITH MY NOKIA MOBILE PHONE BUT THE PHONE ISN'T FINDING THE HEADSET.
have you checked if the battery for the blue tooth is charged? And did you power the blue tooth device on, like wide that of the Nokia phone before you begin pairing?
If all the above are intact and the blue tooth is still not finding the phone, Then you have to test the blue tooth with another phone to be sure its not faulty.
Best regards.
Feb 19, 2010 | Motorola Mobility HS801 Consumer Headset
My samsung t-mobile cellphone cannot access it's blue tooth driver what shoul i do
This happens because the Blue tooth hardware is corrupted to get it repaired you need to walk into the service center.
I hope I was able to help you.
Nov 11, 2009 | T-Mobile Samsung T429 Pay-As-You-Go Cell...
Not working Bluetooth in my Samsung Mobile Model No.SGH-X820
try an antivirus called net protector . load net protector on your main pc, use a cable to connect your mobile to pc using a compatible software for data transfer.
mobile will get detected in the antivirus software,SCAN YOUR MOBILE may be u are lucky to get blue tooth woking , if the file has come through blue tooth netwoking , pushed by some one when blue tooth was on some time. OTHER WISE do a factory reset and save all data first.
if this too fails then the blue tooth hardware/software has to be rectified.
Sep 20, 2009 | Samsung SGH-X820 Phone
6630bluetooth prolem
FIRST OF ALL RESTART YOUR MOBILE PHONE. THEN TURN ON YOUR BLUETOOTH CONNECTION ON YOUR PHONE. ALSO SET YOUR PHONE VISIBILITY ON FROM YOUR MOBILE BLUETOOTH MENU.
THEN TURN OFF YOUR BLUETOOTH DEVICE. NOW PRESS AND HOLD THE POWER BUTTON ON YOUR BLUETOOTH DEVICE. WHEN THE LIGHT BLINKS YOUR BLUETOOTH DEVICE IS DISCOVERABLE FOR YOUR PHONE.
NOW SEARCH FOR A BLUETOOTH DEVICE FROM YOUR MOBILE'S BLUETOOTH MENU. YOUR DEVICE WILL BE DISCOVERED BY YOUR MOBILE. NOW ADD THE BLUDTOOTH DEVICE TO YOUR MOBILE THE PASSCODE SHALL BE 0000 OR 1111.
NOW YOU CAN USE YOUR BLUETOOTH. IF STILL UNBALE TO EXCESS PLS. ASK US.
PLS. RATE MY SOLUTION.
NICE DAY
REGARDS
KETAN PATEL.
Feb 12, 2009 | Nokia 6300 Cellular Phone
Blue tooth
you have to switch on the blue tooth of your mobile phone, switch on your laptop blue tooth also,
now open the blue tooth software on laptop there is a search option , it will detect your mobile phone and will ask for a pass key enter 1234 or any key you like but it be the same on both (laptop and mobile)
after that you send files
Oct 02, 2008 | Toshiba Computers & Internet
Apple iPhone Smartphone Logo
15 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
