Question about GE JBP65 Electric Kitchen Range
Diplay flashes "Bad" then "line" with a loud tone. GE troubleshooting says a possible cause is that the installed connection from the house to the unit is miswired. The unit has worked fine for 2 years and is not miswired. The alarm went off automatically at night when not even in use. I suspect a problem with a sensor.
  • 87 Answers
SOURCE: Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Posted on Jun 08, 2007
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Posted on Jul 07, 2007
mgprice
  • 744 Answers
SOURCE: GE oven functional code F1 appears.
Hello, I come across this problem quite often, The f1 error code does not always follow that it is a bad EOC (Electronic oven control) This could also be a problem with the touchpad. The way to figure which is bad is turn electric off, access the EOC and pull the wire harness/ribbon tape for the touch pad. Reassemble the range and switch power back on. If you are still getting the F1 it is the EOC..If the F1 clears then your problem is with the Touchpad. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Posted on Aug 18, 2009
sams_trix
  • 93 Answers
SOURCE: GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Posted on Aug 29, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Touch sreen won't work
I would suspect it either needs a hard reset (unplugging it for a few minutes, then trying again) or the membrane keypad is failing.
Instead of JMV1540BMC01, it would probably be one of these models:
JVM1540DM1BB
JVM1540DM1CC
JVM1540DM1WW
JVM1540DM2BB
JVM1540DM2CC
JVM1540DM2WW
JVM1540DN1BB
JVM1540DN1CC
JVM1540DN1WW
JVM1540DN2BB
JVM1540DN2CC
JVM1540DN2WW
JVM1540LM1CS
JVM1540LM2CS
JVM1540LN1CS
JVM1540LN2CS
JVM1540SM1SS
JVM1540SM2SS
JVM1540SN1SS
JVM1540SN2SS
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 11, 2009
How do you fix the water dispenser on a GE side by side refrigerator model GSS201EPD WW
Here are a couple of possible problems. Most common one is a defective water inlet valve. It is the plastic assembly at the lower back area where the house water connects to. On dispenser systems it is actually 2 valves in one unit---half lets water in to icemaker---the other half lets water dispense at door. It is electrically operated so if half goes bad , the other half can still work. If bad it needs replaced as a complete unit.
Second possible problem with some GE side by side models is they had problems with the water line in the door going to the dispenser sometime would freeze up. They came out with a heater kit that needs installed in the dispenser area to defrost the water line. Call GE service with your model number and they may be able to tell you if you need that kit installed.
Jun 28, 2015 | GE Refrigerators
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
Why no dial tone. Only static?
If that happens on all phones and you have copper wiring inside and out it usually is caused by a high resistance open (bad wire connection) either inside or outside the house.. If it happens on only one phone it is either ther phone itself (swap with another phone to prove it's the phone) or the wiring to the phone has a loose connection or is bad. If it happens one all phones test it where the telephone connection comes into the house. If it is still noisy the call the local TELCO. Wet lines can also cause the same problem so if you suspect there was any water leaks in the house disconnect the inside wiring from the telephone entrance connection before testing other if the problem is inside TELCO will charge. If you using a wireless phone use a wired phone to do the testing.
Aug 26, 2014 | Lands Phones
Why does my phone says NO LINE and I have no dial tone
Because the phone does not "see" a line. This can be caused by a bad cable, bad plug, or just because the phone is switched off.
It also could be caused by the phone provider, or a bad cable outside your house.
Try plugging in the phone, or the base station, as close to the point the line is coming into your house as possible. Then try again. Check all cables.
If nothing helps, (let someone) call the phone provider to ask if they are aware of the problem.
Jul 24, 2014 | Vtech Lands Phones
Why does my phone say no line?
That means that it is not connected to the wiring that has voice data on it. IT cannot detect the voltage that should be there. Check the wires to the plug in to the phone jack.
Apr 09, 2014 | Lands Phones
Horizontal blinking lines appear on the screen of Sony Vaio VPCEL 10EL
Possible cause:
1. Video card failure.
2. Bad connection between video cable and LCD screen.
3. Bad LCD screen.
4. Faulty video cable.
Possible troubleshooting steps and repair solution:
1. First of all, test the laptop video output on the external monitor. If you see same flashing lines running through the image on the external monitor, you have a problem with the video card. If flashing lines appear only on the laptop screen, the failure is not related to the video card.
2. Just in case, try re-seating the video cable connectors on the motherboard/video card and maybe the back of the LCD screen. It' s not likely but possible that connection is loose and reconnecting the cable will fix the flashing lines.
3. If re-seating the cable connectors doesn't help, most likely you have a faulty LCD screen. The LCD screen has to be replaced.
4. If replacing the screen doesn't help, try replacing the video cable. It's very unlikely that this problem is related to the video cable but there is a slight possibility of that.
Oct 26, 2012 | Computers & Internet
Horizontal lines in picture
my friend CCD imager is going bad !
u have to contact GE they will do it free of cost even if ur not in warranty bcoz it is considered a manufacturing fault by all manufacturers BAD CCD is a big problem these days
actually if the pics are discolored have pink and blue shades or puple and differentt skin tones then my friend ur CCD imager is going bad
u can contact sony they might do it free of charge bcoz it is a big problem in thousands of camera models and all are repairing free of cost as it is considered a manufac fault pls contact SONY in ur area and they will do the rest insist on free repairs and tell them abt bad ccd
see this
http://www.imaging-resource.com/badccds.html
Pls rate me FIXYA for help
Apr 03, 2009 | GE A730 Digital Camera
Modem connects to internet but I have no dial tone to make calls
Usually DSL, like verizon, they comes with filter. check the filter that connects to the phone.
Mar 30, 2009 | Arris Touchstone 450a (CM450) Modem
Bad phone connection
Usually static with loss of tone is a damaged line somewhere. The static can be caused by a loose connection as well as corroded lines. The loss of tone is usually caused by a dead short in the line. I just re wired my dads house for the same thing and eventually found where a rabbit had chewed through the insulation on a wire outside. He was having the exact same symptoms as you are. Hope this helps, and good luck
Jan 07, 2008 | Lands Phones
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
GE JBP65 Electric Kitchen Range Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
