Question about Maytag MDB3100 Dishwasher
Water Inlet Valve for Maytag MDB3100
I have an 8-year-old Maytag MDB3100 dishwasher that isn't filling properly, leading me to suspect a bad water inlet valve. Given the age of the machine, should I replace the valve or just get a new machine? If it's something more than just dirty screens, about how much time will a new valve (however much that costs) probably give me before something else goes south? I know nothing about the reliability record of this model, or if some other major component will probably go out around the 10-year mark, for example, so any input will be appreciated.
  • MtrBao May 27, 2008
    thank you for your feedback, will give it a shot
  • 525 Answers
You can save considerable money if you change the valve yourself. I sold Maytag dishwashers for over 25 yrs. and there are still a lot of those out there. Very simple to work on and last a long time with minimal maintenance.
Posted on May 27, 2008
  • David Emmel
    David Emmel May 28, 2008
    Thank you for rating my opinion. Let me know if If I can be of further assistance.
GE dishwasher GSD6260JSS doesn't clearn as well as when new
water temp should be a minimum 140 degrees at inlet this can be checked with meat thermometer at kitchen faucet,also need proper fill of water entering dishwasher proper water pressure and fill also important for proper cleaning of dishes,if water is slow entering you may have sediment inside fillvalve screen if on well water in this case you will have to disconnect water supply line and take valve apart the screen is in side valve reassemble and test operation...if this does not work you may have to replace inlet vavle
Oct 21, 2012 | Microwave Ovens
No water in dishwasher
I would suggest to check the information by clicking here if you are planning to DIY.
May 20, 2008 | Dishwashers
Maytag MDB6000AWA doesn't fill with water
I had the same problem. Check and clean the sediment screen in the "water inlet valve". If this isn't plugged it is probably the solenoid on the same valve. I replaced the water inlet valve, took apart the inside apparatus of the dishwasher and gave it a good cleaning and this fixed the problem. The valve cost me $60.00CDN delivered to my door. You can order it online for as little as $30-$40.
Mike B.
Nov 09, 2011 | Maytag 24 in. MDB6600A Jetclean II...
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
Water Inlet Valve
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 03, 2011 | Dishwashers
Water will not fill the dishwasher, it runs but it will not fill with the water inlet plugged?
Hello there
The most common causes of this problem are a defective water inlet valve or a stuck float switch. The float switch sits under the dish racks and sends a shut-off signal to the dishwasher when the water level is high enough. Make sure you only use a Maytag-compatible replacement if you have to change out your dishwasher's float switch or water inlet valve.
Difficulty: Moderate Instructions Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Scrub brush
  • Replacement parts (if necessary)
hd_clickable2_area.gifGet what you need for every
project at
  1. 1 Shut off power to the dishwasher from the home's circuit breaker box. Remove the lower rack from the inside of the dishwasher.
  2. 2 Check the water inlet valve to see if it clogged or broken. Replace the valve if you notice any problems and test the dishwasher again. If it still does not fill, proceed to Step Three to troubleshoot the float switch.
  3. 3 Consult your owner's manual to find the location of the float assembly. Remove the cover, if applicable to your dishwasher. There may be retaining screws holding the cover in place or it may just snap off.
  4. 4 Hold both sides of the float while you raise and lower it several times. The float should move freely without binding or catching on anything. Disconnect and use a scrub brush to clean the float if you feel any resistance.
  5. 5 Reattach the float and test its movement again. If it is still not moving properly, replace the float.
  6. 6 Replace the lower rack of the dishwasher and turn the breaker switch back on.
Read more: How to Troubleshoot a Maytag Dishwasher That Does Not Fill '
Jan 05, 2011 | Maytag MDB6769AW Builtin Dishwasher
My Bosch SHU66C is not filling with water. Timer
HI. First you will need to make sure you are getting water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you are receiving water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case the valve should be inspected and replaced, if needed. Us the procedure below to guide you through the inspection process.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
Apr 07, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher runs but no water is flowing to the
Take the kick panel on the bottom front and what you are looking for is an inlet valve its what your water line from under your sink is connected to the dishwasher. You will have an electrical connection on the valve. With a volt meter check to see if you have voltage at the valve when it should be filling with water.If you dont have 110volts then its either a timer or control board problem. If you have voltage when it should be filling with water then it a bad inlet valve.
Jan 03, 2010 | Dishwashers
My dishwasher will drain but will not fill up with water ?
Hello there
Specific symptoms include: Little or no water enters the tub . To find the cause, first check to be sure the water is ON.
always “zero” the ohmmeter before making any continuity checks on dishwasher components. . When making continuity checks with the volt/ohmmeter, always turn the electricity OFF at the circuit breaker panel. Live voltage checks will damage the meter movement.With the water ON, remove the lower panel. Place a towel or shallow container on floor to absorb water. Loosen the nut that secures the dishwasher water tubing to the inlet port of the water inlet valve. If water collects immediately in the towel or container, it can safely be assumed that the water pressure is adequate and the plumbing system is not clogged . If little or no water collects in the container, the water line gate valve could be defective or there is a problem in the plumbing system.
Turn the water OFF. Remove the lower panel. Loosen and remove nut that attaches water tubing to water inlet valve inlet port. With tubing removed, check for corrosion and debris that has accumulated inside the tubing and inlet valve inlet port. . Turn the water supply ON. Select a cycle on the timer dial where the dishwasher starts to fill with water. If it starts to fill with water — you fixed it. The problem was corrosion inside the water tubing or inlet valve water inlet port. If the dishwasher still does not fill with water, an additional electrical check will have to be made.Next, test for electrical power to the water inlet valve from the dishwasher timer assembly. Using the volt/ohmmeter, set the meter on the 150-volt scale and attach the two test leads of the volt/ohmmeter to the two terminals of the water inlet valve solenoid coil to be checked. Turn the water ON. With the test leads attached to the solenoid terminals, select a cycle on the dishwasher timer dial where the dishwasher starts to fill with water. Push in or pull out the timer dial. You should get a voltage reading of 110-125 volts A/C on the volt/ohmmeter scale. If you get a reading, this would indicate that electricity is available from the dishwasher timer assembly to the water inlet valve.However, the absence of water flow means the water inlet valve is defective
Dec 31, 2009 | Maytag Dishwashers
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
Leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Dishwashers Logo
144 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
