Question about Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Panasonic DVD Recorder DMR-EX79, still under warranty. How do I change the time (clock) to daylight saving time. Thank you. jean Palmer jpalmer83@optusnet.com.au
Demonic-2011
  • 467 Answers
SOURCE: How do you reset clock on your DVD Recorder
You can either copy and paste the following link into your browser, for quick-view, and/or save the .pdf document (instructions for Panasonic DMR-ES15 DVD recorder):
http://videolinq.tafe.net/attached_docs/pdf/equipment/Panasonic_DMR-ES15_User_Manual.pdf
(verified and complete to give you a basic operation manual for FREE download)
or you can try to set the clock manually, do this:
press [FUNCTIONS] on the remote while unit is on, to bring up the setup menu, scroll to 'OTHERS' look for 'CLOCK' or 'CLOCK SET' option, highlight it, click it, set the clock. Press [ENTER/OK] to access the date hour minute, etc., then press the relevant remote arrow buttons to select correct time/date, then press [ENTER/OK] to store the current setting. Then press [RETURN] to exit the setup. Clock is now set (this model does not offer automatic clock adjustment for daylight saving).
If the above suggestion does not work, download the pdf and save it for accurate reference. Either may help you.
Posted on May 01, 2011
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
Bati99
  • 88 Answers
SOURCE: panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Posted on Apr 19, 2009
nandosnut
  • 112 Answers
SOURCE: setting the clock on the dvd recorder
Follow this sequence on the remote control:
Press FUNCTIONS/To Others/Setup/Others/Clock to access the clock setting mode. There, you will have the choice of Auto or Manual. Take your pick and away you go!
Posted on Apr 20, 2009
How do you reset clock on your DVD Recorder DMR-ES15. Can't find booklet that came with recorder.
May 01, 2011 | Panasonic DMRES15 DVD Recorder
Switched on my panasonic DMR EX79 HDD/DVD recorder and came up with a U80 code (did not start up properly). Followed the troubleshooting guide in manual by turning machine on and off but this does not fix...
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Jul 01, 2010 | Panasonic DMR-ES20EG DVD Recorder
The time show late every single day..every day i must turn the right time..
Do you have your DVR set for automatic clock updates? I changed mine to manual clock settings because of problems with the new dates for Daylight Savings Time. Every few months I have to adjust the time by a minute or so if I find I am missing the intro to programs that I record. I also have to do the Daylight Savings Time shifts each fall and spring.
Nov 21, 2009 | Panasonic DMR-E55 DVD Recorder
Cannot set clock on DMR-EH75V DVD player?
On this model you must hook-up a antenna or cable to ant input and start with first time setup and wait 24 hrs with the power off for it to gather guide information. I Have a setup guide or go to Panasonics website at www.panasonic.com/dvdhelp/ you must also connect the video out to video in on your tv.
Apr 12, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Won't allow manual clock set - tv guide not loading
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
will self check, say test L1, power off, on again.. go thru setup. no data was lost.
Apr 04, 2009 | Panasonic DMR-E85H DVD Recorder
Can't change the clock time
Best Solution posted Nov 6, 2008, by Guest -- worked for me. Wondering what the DST is? -- Daylight Savings Time. There will be a button at the bottom right in the date OFF. Apparently the TV Guide programing does not work that well, especially with the new Digital boxes now need to receive over the air TV and the TV Guide programing never worked with Satellite TV. Wil this feature ever be up dated? I doubt it. It would be nice to have the digital box and your dvr cycled together.
Nov 03, 2008 | Panasonic DMR-E85H DVD Recorder
Clock adjustment
I turned off the daylight savings feature and then adjusted the clock. It can be turned on after making the adjustment.
Dec 13, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic dvd video recorder dmr-e55 user manual
http://service.us.panasonic.com/OPERMANPDF/DMRE55.PDF
Oct 13, 2007 | GoVideo Home Audio&Video: Go-Video DVD...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
128 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
