Question about Motorola Mobility RAZR V3
Bluetooth connectivity problems
I have tried to connect to two different bluetooth devices (one Motorola, one Jabra) and my RAZR was unable to find them. I really don't want to try a third. can you help me?
    Brigadier General:
  • 7,752 Answers
Master reset your phone....then try again.
Posted on Jun 02, 2008
I recently got the Motorola Droid X and paired & connected by jabra vbt2050 with it and it worked. Today though, when placing a call with the Jabra, I could hardly hear the call. Now I have not power...
To see if the problem is with your bluetooth connection, try sending and recieving files with your bluetooth. If it is successful, then try borrowing 1 jabra device and test it with your phone. The bluetooth connection and the jabra device are the problems I can see since you said it worked once.
Hope this helps! -jayps
Mar 09, 2011 | Cell Phones
Unable to pair Jabra 5050 with Motorola qa1. Bluetooth is on in both devices, unable to find device from QA1 or from BB.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Dec 14, 2009 | Jabra SP5050 Bluetooth Headset
Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
Bluetooth handfree not working
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
Apr 30, 2008 | Motorola Mobility RAZR V3
Pairing Jabra BT135 with motorola L2
Your not doing anything wrong it usually means that the headset isn't capable with ur razr or you need to reset both of them and try it again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3m Cellular Phone
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Feb 11, 2008 | Motorola Mobility L2 Cellular Phone
Connects but won't pair
to connection to your phone or device
turn off your jabra then press and hold the big white button until the light stay on the search for your device
Dec 25, 2007 | Jabra BT125 Headset
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Dec 14, 2007 | Motorola Mobility RAZR V3
Motorola Razr V3 will not connect to TomTom Go910
you need to set the bluetooth to on. then set to shown to all, it will automatically find the device, and if theres a pass key you need to enter the same key on both phones to connect.
Sep 26, 2007 | Motorola Mobility RAZR V3
Bluetooth doesn't shut off on its own unless you turn off your phone. In the bluetooth options, you should be able to select "Turning Bluetooth On", "Turning Bluetooth Off", or "Using Discovery Mode (60 seconds)." Discovery Mode, which I believe is what your using, is only used when connecting to another device. My question for you is, what kind of device are you trying to connect to?
Sep 05, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
